- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
"Connecting to the admin page"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I can see from searching that this has happened to others.
My NAS did an upgrade yesterday to 6.10.5 and now when I try to access the admin page it is looping i.e. it asks for the username and password then after a few seconds goes to "Connecting to the admin page" then asks for the username and password again.
I have 3 NAS this one, a RN314, and a Pro 6 all running 6.10.5 the 314 and 6 are fine.
There is something a bit weird with the 104 - I can see a share "admin" when I look at the device in file explorer "Network" which I don't recognise. I know that HTTP maps to a folder called "admin" and wondering if there is a conection.
I have downloaded the logs.
Can anyone help?
Do do have a backup from a few days ago so a factory reset would not be the end of the world but copying the data back 3.6TB will take time...
Thanks
Paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: "Connecting to the admin page"
That's a private "home" folder - you are seeing it because you are using the NAS admin credentials.
Similarly when you access https://nas-name or https://nas-ip-address (without the /admin suffix) and use the NAS admin credentials as the log in.
You can disable it by turning SMB off on the Home "share" in the web ui.
@JohnCM_S / @Marc_V : Do you folks want to take a look? This issue appears to be showing up for several users.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have done a factory reset and re-installed the firmware and for a little while everything worked fine.
Within a matter of minutes the unit has started looping again.
The firmware re-installed was either 6.10.5 or it has updated to this version.
Is there any way of going back to 6.10.4?
- Mark as New
- Bookmark
- Subscribe
- Permalink
One poster found they could log in with internet explorer. One important aspect - the log in also required that they not maximize the browser window.
If you can log in, then you can downgrade back to 6.10.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried ie (not maximised) and that loops too.
I will try some other browsers and report back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
After further investigation everything works with 6.10.5 until you change the ethernet settings (I used a fixed IP address) it seems to be at this point that everything goes pear shaped.
I have gone back to 6.10.4
I also noticed that if you create shares using readycloud in 6.10.5 you cannot change the access from "everyone" when connecting via "management" i.e. connecting locally.
Anyway now running 6.10.4, new shares deleted and recreated locally and everything seems to be working as needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would just like to add my name to the list of users now experiencing this issue.
I tried to do a USB Firmware reinstall of 6.10.5, but that didn't work.
Checking my log, seems to be something possibly up with the firmware progress check, as it always ends at this place:
INFO: dpv_=<redacted>, njl_id_=<redacted>, type=FirmwareProgress
Then it goes back to the signing in text.
I can see from previous entries in the log that after the above line, there should be a final Authorized granted for user:, which it doesn't seem to be getting to.
I've got 6.10.4 to back to, so hopefully that fixes it for the time being.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I assume there is a way to downgrade from 6.10.5 back to 6.10.4 via SSH without losing any data, is that possible?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did my downgrade this way:
1. Using the boot menu "load firmware" and while the NAS is doing its thing...
2. Download firmware from Netgear and extract to desktop
3. Without changing any factory settings go to "System" -> "settings" -> "Manual Install Firmware"
I then made the changes I wanted i.e. fixed IP etc.
So far it is working as it should.
I hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Paul, will give that a go! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Zippyduda wrote:I assume there is a way to downgrade from 6.10.5 back to 6.10.4 via SSH without losing any data, is that possible?
Yes. Installing firmware updates via SSH has been possible with every firmware release of OS6. Though of course you shouldn't rely on firmware updates or downgrades going smoothly and regularly backup your data.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some options are here: https://community.netgear.com/t5/ReadyNAS-Beta/Beta-firmware-broke-web-interface-6-10-5-T11-Beta-1/m...
