Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
readyNas Duo will not boot to Factory default
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-16
01:16 PM
2013-04-16
01:16 PM
I've a readyNAS Duo v2 which I have replaced with an NV+. I'd like to pass on my Duo but can't remember the admin password (I know!). I'm attempting to do a factory reset but having trouble.
The documentation says press the reset and power on, waiting for all LEDs to light; but they don't. How long does it take? I've held the reset for several minutes but still nothing.
I'm pretty IT savvy but I wonder am I missing a step?
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-16
01:29 PM
2013-04-16
01:29 PM
Re: readyNas Duo will not boot to Factory default
If you are passing on the duo with disks, you can also just put the drives into a PC and use Windows Disk Manager to delete the volumes (right-click on computer, select "Manage"). Or use WD Lifeguard to write 0s to the drive (that works with all drives, not just WD). All the info (including admin password) is on the disks.
Are you certain you have a v2 (running 4.1.x firmware)?
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-16
02:06 PM
2013-04-16
02:06 PM
It is a Duo v2 - I can't swear to the os level as it was laid aside for a while (hence forgetting the admin p/w). I am passing it on but with new disks. I can set the RAID level and get it running but without the admin can't set it up on the new network or configure the shares.
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-16
03:21 PM
2013-04-16
03:21 PM
If you are using new disks, then all you need to do is insert the blank disks and power up. The NAS will install the OS partition on the disks and set up RAID.
After the install, the admin password for the v2 is "password". For the v1 it would be "netgear1".
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-17
01:14 PM
2013-04-17
01:14 PM
Thanks I'll give that a go.
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-04-17
02:16 PM
2013-04-17
02:16 PM
Worked fine. Thanks Stephen
Message 6 of 6
