- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
sabnzbd causes high system load
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Is it normal that sabnzbd drives the sysload up to 143? (as reported in the top right corner of the web interface)
I see three recently finished downloads (with "busy" spinners) in the History section, and one says "repairing 66%".
Can I tell it to behave better during this stage of the download process?
Thanks,
Tony
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think the NAS runs fine until sabnzbd begins repairing one of the downloads. So, I'll switch that function off (per the last post here). And then hopefully I'll be able to see which downloads need intervention, and run those repairs manually from my Mac.
However, now sabnzbd isn't able to start up. Are you able to take a look please?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: sabnzbd causes high system load
You probably should also post this in the sabnzbd forum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does TOP give any clues?
Tasks: 413 total, 5 running, 408 sleeping, 0 stopped, 0 zombie %Cpu(s): 59.1 us, 28.5 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 12.3 si, 0.0 st KiB Mem: 508720 total, 391488 used, 117232 free, 428 buffers KiB Swap: 1047420 total, 326248 used, 721172 free. 21276 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 2756 admin 20 0 644432 80764 3144 S 33.0 15.9 305:14.18 sabnzbd 2669 root 20 0 246188 10628 1284 S 32.7 2.1 1329:56 lite_mv 22335 admin 20 0 22164 17852 276 R 13.5 3.5 191:38.58 par2 404 root 20 0 0 0 0 S 10.7 0.0 92:22.97 kswapd0 1095 root 20 0 0 0 0 S 3.9 0.0 146:20.98 md127_raid5 13338 tony 20 0 5784 1768 1160 R 2.5 0.3 0:00.52 top 10203 root 20 0 0 0 0 S 1.9 0.0 0:18.38 kworker/u2:4 3 root 20 0 0 0 0 R 1.1 0.0 119:16.63 ksoftirqd/0 9821 root 20 0 0 0 0 S 0.8 0.0 0:19.37 kworker/u2:0 981 root 0 -20 0 0 0 S 0.3 0.0 15:20.16 kworker/0:1H 2376 root 20 0 23596 1308 1112 S 0.3 0.3 2:56.19 minidlnad 7837 root 39 19 10404 916 844 D 0.3 0.2 0:00.84 archive_mrg_mv 12502 root 20 0 0 0 0 S 0.3 0.0 0:02.41 kworker/u2:5 29327 root 39 19 10404 892 820 D 0.3 0.2 0:03.34 archive_mrg_mv 31729 root 39 19 10404 1032 960 D 0.3 0.2 0:02.94 archive_mrg_mv 1 root 20 0 26648 536 292 S 0.0 0.1 0:27.05 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.19 kthreadd 5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H 7 root 20 0 0 0 0 R 0.0 0.0 4:59.89 rcu_sched 8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh 9 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0 10 root rt 0 0 0 0 S 0.0 0.0 0:02.60 watchdog/0 11 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper 12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs 13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns 273 root 20 0 0 0 0 S 0.0 0.0 0:00.17 khungtaskd 274 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback 276 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto 277 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
I've also noticed about 200 processes like this:
/apps/surveillance/bin/archive_mrg_mv autobackup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi twc,
Where you able to get in touch with sabnzbd if this is normal for their app? I could have you case be checked but I need to now if the app is working as it should be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Framer, this is what we're up to over on the SAB forum:
Repairing takes a lot of CPU power. That is what you experience. ...
Your ReadyNAS 10400 is a low-spec machine, so you'll never get the same speed as on a
PC with an Intel Core CPU. ... Your sysload values are so insanely high and your top
output does not match that, that 1) something else must be going on (like disk IO problems)
or 2) there is a bug in your OS / Python / SABnzbd reporting
Are you able to help diagnose?
Is he talking about par2? Is there a known issue with that perhaps, on the 10400?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi twc,
The support from SAB is actually trying to point out 3 possibilities I think.
1. The ReadyNAS is under powered and it taking most of its resources when a repair is happening.
2. An HDD failure.
3. A possible issue with our OS.
For the 2nd concern, we can check that via the system logs.
How do I send all logs to ReadyNAS Community moderators?
For the 3rd concern, updating to our latest firmware would be our way to go.
ReadyNAS OS 6 Software Version 6.6.1
Once we check these and see that everything is okay. We can say that the ReadyNAS is just that not powerful enough to handle the repair with ease.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Framer.
Sorry for the slow reply. I was waiting (in vein) for the system to come back online. In the end, I had to flick the power switch.
I've sent the logs so you can check if the disks are okay.
And I am already on 6.6.1 - but this doesn't rule out an issue with par2 or python, does it? How would we go about diagnosing such a thing? Can we compare the performance of par2 between different ReadyNAS systems maybe?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
The load that par2 creates scales with the (number of data blocks) * (number of repair PAR blocks used). So that would be variable.
Are you seeing issues outside of sabnzbd? Perhaps poor NAS throughput when the app is running, or problems reaching the NAS web ui?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi twc,
Are you on the latest firmware already? Does it have an error message?
Would be best to consult the app developer about it as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi twc,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Framer,
Yep, im on the latest firmware. And there's no error message. It just doesn't start, when i flick the app switch to ON.
I've also posted in the developers forum, and hope they'll have some suggestions for me soon.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i've uninstalled it, but now i cant find it in the list of apps to reinstall? can you remind me how to install it please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Were you using the SABnzbd from the avaiable apps?
It was a little dated, but it looks like there is an updated one if you wanted to pay for it:
I started working on an updated version of that app. I took a quick look at where I was at and might be able to get it done this week running the latest 1.2.0.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Mhynlo. Yes I think I installed it from the "available apps" page.
Whats the difference between the version you pointed me at (for €2.99); and the version that you might release this week?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The app version that I pointed to is the original dev that had his app on the "available apps". He has not updated the app there and requests support through app purchase.
My apps that I post are open source and submitted for "available apps". I have been updating some of the apps when I get time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd rather get it from "available apps", so will wait for your release thank you Myynlo.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got it, thanks for clarifying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are some things that make it easier to go the available apps like knowning what are the available ports, notifying users there are updates, and seems like there ares some testing they run before posting.
Either case; I was able to get most of SABnzbd:
https://github.com/Mhynlo/readynas-sabnzbd/releases/tag/1.2.0-0
I flagged it as pre-release because there are some little things I want to do for hte build process, but the app itself should all be ready and will not be touched when I submit to Netgear.
Please give it a try and let me know what you think.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Mhynlo, thanks so much for this. I put the news server into the wizard, but I get the following when trying to connect to the web interface (at https://192.168.18.17/sabnzbd/😞
Lost connection to SABnzbd..
In case of SABnzbd restart this screen will disappear automatically!
Sometimes I also see this:
Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET /sabnzbd/config/.
Reason: Error reading from remote server
Apache/2.2.31 (Debian) Server at 192.168.18.17 Port 443
Should I give it more time? Maybe it's still running installation related scripts? (although it's been half an hour or so)
- Mark as New
- Bookmark
- Subscribe
- Permalink
It still seems to be slow and dropping the connection.
The previous version didn't do this (ie. the version that was visible in "available apps" before I upgraded the firmware).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've rebooted the NAS and SAB seems to be up and responding now. Will play around with it a bit tomorrow and see how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks good, thank you so much Mhynlo.
