carlocki
Feb 04, 2022Luminary
second usb hdd not always connect (quite never)
Hi Friend
not always my second external usb drive is connect to the nas
the first one on rear port 1 work the second on rear port2 not always. I backuped on both sucefully
[SOLVED]
i FORMATED THE HDD DIRECTLY INSIDE THE NAS AND NOW EVERY RESTART HAS NO ISSUES
- SandsharkSensei
Do they have thier own power supplies, or are they USB powered?
- carlockiLuminary
yes 2 adapters
carlocki wrote:not always my second external usb drive is connect to the nas
I don't use USB drives myself (I back up to other NAS) - so I can't offer much advice.
Is the problem drive externally powered? Or is it getting power from the USB port of the NAS?
- carlockiLuminary
his is the real last issue that i have
with just one hard drive
i have to unplug it and remove usb to restart the connection.
it is the last issue of all the entire system
I'm not sure I understand what you mean by "restart the connection".
Are you saying you need to do this after you boot up in order to access the data on the drive?
Or something else?
- carlockiLuminarysimplier do I have always to re-unplug this hdd everytime?
