Tomas1
Feb 23, 2009Aspirant
Is it possible upgrade firmware via ssh console ?
Hello,
We have cca 200 devices around Central Europe.
We found that we can not update firmware via web interface(local update, web update is not possible because of proxy policy). It fails every single try. Is it possible to get some HowTo, how to do that via console ? Upload to specific directory, check of file, run update.
And why do we need udate it ?
Portmap and frontview is killed by OS too often. We would like to try update.
Hostname: NAS41650
Model: ReadyNAS NV+
Serial: 000da201fac3
Firmware: RAIDiator 4.01c1-p2 [1.00a042]
Memory: 256 MB [ 2.5-3-3-7 ]
Feb 20 14:21:34 NAS41650 kernel: oom-killer: gfp_mask=0x200d2, order=0
Feb 20 14:21:34 NAS41650 kernel: [8005d6e0 : do_wp_page+0xe8/0x738 ] [8005f384 : __handle_mm_fault+0x470/0x4a4 ] [8032d0f4 : 0x8032d0f4 ] [8032c110 : 0x8032c110 ] [2000976c : 0x20009
76c ]
Feb 20 14:21:34 NAS41650 kernel: Mem-info:
Feb 20 14:21:34 NAS41650 kernel: DMA per-cpu:
Feb 20 14:21:34 NAS41650 kernel: cpu 0 hot: high 0, batch 1 used:0
Feb 20 14:21:34 NAS41650 kernel: cpu 0 cold: high 0, batch 1 used:0
Feb 20 14:21:34 NAS41650 kernel: DMA32 per-cpu: empty
Feb 20 14:21:34 NAS41650 kernel: Normal per-cpu:
Feb 20 14:21:34 NAS41650 kernel: cpu 0 hot: high 18, batch 3 used:2
Feb 20 14:21:34 NAS41650 kernel: cpu 0 cold: high 6, batch 1 used:5
Feb 20 14:21:34 NAS41650 kernel: HighMem per-cpu: empty
Feb 20 14:21:34 NAS41650 kernel: Free pages: 5584kB (0kB HighMem)
Feb 20 14:21:34 NAS41650 kernel: Active:391 inactive:309 dirty:0 writeback:1 unstable:0 free:349 slab:1023 mapped:205 pagetables:0
Feb 20 14:21:34 NAS41650 kernel: DMA free:3216kB min:112kB low:128kB high:160kB active:0kB inactive:0kB present:16384kB pages_scanned:0 all_unreclaimable? yes
Feb 20 14:21:34 NAS41650 kernel: lowmem_reserve[]: 0 0 60 60
Feb 20 14:21:34 NAS41650 kernel: DMA32 free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Feb 20 14:21:34 NAS41650 kernel: Normal free:2368kB min:1840kB low:2288kB high:2752kB active:6256kB inactive:4944kB present:245760kB pages_scanned:128 all_unreclaimable? no
Feb 20 14:21:34 NAS41650 kernel: lowmem_reserve[]: 0 0 0 0
Feb 20 14:21:34 NAS41650 kernel: DMA32: empty
Feb 20 14:21:34 NAS41650 kernel: Normal: 34*16kB 1*32kB 2*64kB 1*128kB 0*256kB 1*512kB 1*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 2368kB
Feb 20 14:21:34 NAS41650 kernel: HighMem: empty
Feb 20 14:21:34 NAS41650 kernel: Swap cache: add 6926959, delete 6926886, find 856341/3689643, race 144+569
Feb 20 14:21:34 NAS41650 kernel: Free swap = 1563632kB
Feb 20 14:21:34 NAS41650 kernel: Total swap = 1572640kB
Feb 20 14:21:34 NAS41650 kernel: Free swap: 1563632kB
Feb 20 14:21:34 NAS41650 kernel: 14151 pages of RAM
Feb 20 14:21:34 NAS41650 kernel: 349 free pages
Feb 20 14:21:34 NAS41650 kernel: Out of Memory: Kill process 31624 (portmap) score 140 and children.
Feb 20 14:21:34 NAS41650 kernel: Out of memory: Killed process 31624 (portmap).
- dbott67GuideFrom chirpa:
$ cd /tmp
$ wget http://www.readynas.com/download/RAIDiator/RAIDiator-4.1.4
$ echo /tmp/RAIDiator-4.1.4 > /.cf_update_in_progress
$ reboot
Keep in mind that the command will change with each firmware revision that's released:
$ wget http://www.readynas.com/download/RAIDiator/RAIDiator-X.Y.Z - Tomas1AspirantThat was fast.
Thank you so much :) - martinaheevaAspirantDid this have work for you?
- pacifoxAspirantHi,
With the same method, it is possible to upgrade an addon ?
Thank's - mdgm-ntgrNETGEAR Employee RetiredThis method does work for updating the firmware. Not recommended though as it skips the check to see if the firmware image is corrupt.
No updating add-ons is done differently. What add-on are you seeking to update? - mdgm-ntgrNETGEAR Employee RetiredShould be clear that it is possible to install some add-ons via SSH but the method is different.
