- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN102 - can't connect to web-interface after uninstalling app
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m new user here because I have problem whit my ReadyNas 102
Can't connect to the web-interface (web admin panel). Installed and uninstalled the ReadyNAS Photos II app.
Already tried to instal the new beta firmware 6.2.3 with the boot menu but no luck
I hope someone here can help me.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK So I have fixed my issue without having to go to the linux level
If you have set up a readycloud account, you can log in there and upgrade your firmware remotely.
This worked for me, I hadn't thought of this until Netgear informed me that my readycloud account was going to close and once I got in I upgraded the firmware and now I can access the admin page through the network
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN102 - can't connect to web-interface after uninstallin
Welcome to the forum!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem with my ReadyNas 102...
Can you help me?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Btw I fixed wolay's system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
mdgm wrote: Btw I fixed wolay's system.
Hi
How can you update the OS when you cannot acces the admin page ? I had to do a factory reset and then do the update of the OS.
Robby
- Mark as New
- Bookmark
- Subscribe
- Permalink
In any case when I fix this problem currently I remove the broken symlink, I don't update the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
# journalctl -a | grep apache2 | tail -n 20
# cd /etc/apache2/sites-enabled
# ls
# rm *shell*
# systemctl restart apache2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I am in the same case.
ReadyNas works fine to access the file but impossible to access the admin interface.
Too bad you send the trick to restore it in PM 🙂
Thanks for your help,
Mickael
- Mark as New
- Bookmark
- Subscribe
- Permalink
@M69S wrote:
Hi
Mickael
Do you have ssh access? What firmware are you running?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope SSH does not seem to be enabled and I don't know the exact firmware number (something like 6.x)
I am currently backuping the data (only 15h left 😃) before doing a factory reset.
I just hope that it won't happen again ! And next time I will enable ssh.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am unable to ssh into the system but can boot the readynas 102 into boot mode and telnet in using putty
When i try
I get
-sh: cd: can't cd to /etc/apache2/sites-enabled
when I check the contents of /etc apache2 is not there
if I try
I get the response
-sh: journalctl: not found
not sure what else I can do 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you mount the OS partition?
- Mark as New
- Bookmark
- Subscribe
- Permalink
hmmm no, I only have limited knowlege of linux systems and was not aware I had to mount the partition
What is the process to mount it?
I did a quick search on google, would the following be sufficient or are there more commands that need to be executed?
# start_raid.sh
# mount /dev/md0 /sysroot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure you want to start RAID
Perhaps try
mount /dev/md0 /mnt
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get the following
___________________________________________________________
# mount /dev/md0/sysroot
mount: can't find /dev/md0/sysroot in /etc/fstab
# pwd
/root
mount: mounting /dev/md0 on /sysroot failed: No such file or directory
# cd /sysroot
# mount /dev/md0
mount: can't find /dev/md0 in /etc/fstab
# # mount /dev/md0 /sysroot
# mount: mounting /dev/md0 on /sysroot failed: No such file or directory
-sh: mount:: not found
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why are you trying to mount to a non-existent folder?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN102 - can't connect to web-interface after uninstalling app
I have the same problem please advise
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
RN102 / 6.4.1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also imac with el capitan 10.11.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
What app did you uninstall?
- Mark as New
- Bookmark
- Subscribe
- Permalink
