walshlink's avatar
walshlink
Luminary
Dec 27, 2015
RNP 6 w/ Xeon CPU and upgraded fans
Changes made to keep RNP 6 cool after upgrading to Xeon CPU:
OS: 6.4.2 Beta 1
Installed/Modified:
Delta 80x15mm PWM EFC0812DB, 48.8 CFM, 3800 RPM, 41 dBA
Noctua 120x25mm 3-pin NF-F12 Industrial PPC-2000, 71.5 CFM, 2000 rpm, 29.7 dBA
Ran the following command from SSH:
# echo 2000 > /etc/frontview/min_fan_speed_override
Reversed CPU fan to suck air in
Removed plastic film between CPU/MB compartment and System Fan compartment
Results:
No CPU load
- CPU Temp - 35C
- CPU Fan RPM - 1600
- System Temp - 46C
- System Fan RPM - 2000
CPU load after 10 mins (scrubbing volume)
- CPU Temp - 57C
- System Temp - 50C
    I thought the cpu fan is originally set up to be blowing from outside towards the heatsink
  • Probably was...when I upgraded fans, I probably eff'd it up...so yes, blow/suck air IN...
    • viperhansa's avatar
      viperhansa
      Virtuoso
      Hi guys...
      If i only want to speed up system fan minimum rpm's? Is that possible?
      // Hans
      • mdgm-ntgr's avatar
        mdgm-ntgr
        NETGEAR Employee Retired
        You could run the echo command walshlink mentioned earlier in the thread or a similar one. His example sets the minimum fan speed to 2000 RPM.
  • It appears to me to only be applied to the System fan, not to the CPU fan. I would like to set a threshold for my CPU fan as well. Also, I have noticed CPU temps can get up to 60C before CPU fan starts ramping up. Is that normal? I wished it started ramping up at much lower temps.
      mdgm-ntgr
      You can make your own custom sensors file if you want to do more advanced changes to settings.
      The fans will spin up when needed. Though of course if you use a 3rd party CPU then a custom sensors file may be a good idea to have settings tailored to what works well with that CPU. Our sensors files would be designed for stock hardware.
      • walshlink's avatar
        walshlink
        Luminary
        mdgm,
        Are you talking about modifying the system.conf under sensors.d?
ProSupport for Business
