× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Extend WIFI Coverage
NWest1965
Hi Community
I have the Nighthawk R8000 plugged into my study which is on one side of my house and as I get towards the far side of my house I lose WIFI coverage almost completely.  What is the best way to get an extender on the other side of my house that I am able to simply plug into electric (i.e. I cannot put an ethernet cable around the house for this).
Thanks.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Guru
Re: Extend WIFI Coverage
you could use a wifi extender, you could use a powerline device with built in wifi, or you could even use a moca adapter (ethernet over coax).
Several different options for you.
Message 2 of 5
NWest1965
Those are all pretty expensive solutions when I already have a pretty expensive router!  Would your EX6250 do the job, but with a little less performance??
Are there any others lower in your range that would also do the job.
Message 3 of 5
Guru
the models I have listed are just my signature. They're not recommendations.
You have multiple options that you can try. I just listed extenders, powerline, or moca adapters.
The ex6250 might work fine for you.
Message 4 of 5
NWest1965
OK, understood, much appreciated
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 650 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
