- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netflix not streaming
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello. I installed the extender. All works fine besides Netflix streaming. I can get I to Netflix but streaming does not work. It times out. I tried to only enable the 5 Band or also with or without the same name. The problem persist. What can I do? The streaming works on the base station WIFI. Thank you in advance. P.S. I am on the newest firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netflix not streaming
Hi @thesieger,
Try to modify wireless channel on your main router since that may impact signal which you get from your extender.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @thesieger,
What is the speed which you get from main router at the place where extender is and what speed do you get on the device from which you are trying to access Netflix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Directly to the router with the end device 105, then connected to the extender 90 mb.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @thesieger,
Speed via extender looks fine compared to router. So you shouldn't face issues while streaming Netflix. May I know from what device are you trying to stream Netflix? What is you try from a different device just to find out where issue could be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @thesieger,
Try reset and reconfiguring the extender to check if your issue persist.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Already done twice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @thesieger,
Try modifying wireless channels on both bands on your main router to check if that helps. You can try wifi analyzer apps which can check and suggest best channel for your environment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @thesieger,
Never heard any so far. How about if you try to stream anything else like Youtube?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @thesieger,
Please contact Netgear support since this looks odd. It works for others who have the same model.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
