- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear N300 connection timeout
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mufcboy234 wrote:
It rises.
Then the next troubleshooting step is to sort out whether this is internet congestion or an issue with the WiFi/extender throughput. The steps above should help sort this out.
Another option is to upgrade to a higher-performing extender. That won't help if the issue isn't with the WiFi/Extender throughput.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear N300 connection timeout
Is the connection actually timing out, or are you just seeing a rise in ping times?
A rise in ping time has two basic causes:
- the ping packet is getting dropped by the extender or the router WiFi, and needs to be re-sent.
- there is congestion on the network path (not necessarily wifi).
The next time it rises, maybe try pinging from a machine that is connected by ethernet to the router. There is a tool called pingplotter that could be useful (it is quite expensive, but you could just use it during the trial period).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mufcboy234 wrote:
It rises.
