Reply
WNDAP660
CTM5
WNDAP660
I have connected external antennas to the Prosafe access point. However I am unable to locate the setting in the interface to switch from internal to external antenna. The set up instructions indicate that this should be done. Can anyone help please.
Model: WNDAP660|ProSafe 3x3 Dual Radio Dual Band Wireless-N Access Point
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: WNDAP660
Advanced -> Advanced Wireless Settings ->  Antenna
Select one of the following radio buttons to specify the antenna:
• Internal. Enables the internal antenna. This is the default setting.
• External. Enables an optional external antenna or antennas.
Note: This setting does not apply to the 802.11a/na modes. The way I read this: 2.4 GHz only, not 5 GHz.
Reference: NETGEAR ProSAFE Premium 3 x 3 Dual-Band Wireless-N Access Point WNDAP660 Reference Manual, p.108 ff.
Moderator, please move subject (and it's duplicate post) to the Business Wireless section, thx.
Message 2 of 3
All Replies
schumaku
Guru
Re: WNDAP660
Message 2 of 3
CTM5
Re: WNDAP660
Many Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2387 views
  • 0 kudos
  • 2 in conversation
Announcements
