Help
13 TopicsReadynas RND-6a doesn't boot
I got this NAS used and so am unsure as to how it works. The model is Readynas rnd-6a. When I power it on the fans spin up and "ReadyNAS" displays on the LCD but that is all. I assume it doesn't boot although I don't know how to check if it's online, I have plugged in an Ethernet cable and it doesn't show up on my router. So far I have tried: Removing all the disks External power supply Changing the memory There is no data it, I just want to resurrect the machine. Any info or solutions would be greatly appreciated. Thanks, ConnorSolvedRN314 Disk corruption
I've had this RN314 for a few yeras now but its been nothing but headaches, Right now Its holding my data hostage. It Keeps telling me error 0x80070570 The File or Data is corrupted - I am running the NAS as a Raid-5 so i had hopes that a scrub should fix this issues. But it did not. Ther are no disk errors in Smart. I am currently Migrating my data to the cloud If this was only 1 or 2 files no big issues but as of now its over 20% of all the files on the drive. The good news is the files seem to still be playable and work for me if i manually navigate to them... If this was windows I'd run a check Disk on them, but I dont know what to do with this RN. HELP.Questions about the ReadyNAS 424
I am new here and am concidering getting a Netgear ReadyNAS 424. I currentley have a Asustor AS-5004T and want to upgrade it to something better what must incldude native windows based File versioning support (Previous Versions) for SMB shares held on the NAS. My current setup is as follows, I have 2 x 6TB WD Red Pro HDD's inside my exsiting NAS box confiqured in RAID 1 along with a 4TB Red Pro drive used for weekley archiving. I also have a another 6TB WD Red Pro HDD inside my Windows 2016 Essentials rack server what acts as a backup to my main 6TB RAID 1 array. I have a few questions about the ReadyNAS 424, and hopefully those reading will be able to ansewer for me. 1) Can the RAM on the ReadyNAS 424 be upgradded, and if so to how much and what type? I have 8GB in my AS-5004T at the moment and is of the 1600MHz DDR3L SO-DIMM type. (Will 2GB be enough!? , my NAS is my main storage for daily usage and not just a backup/archive) 2) At what level does the ReadyNAS 424 support DFS and file versioning. I would like it to idealy integrate with the DFS capabilitys of Windows Server and have the 6TB drive inside my Rack Server cross syncronise the SMB shares on the ReadyNAS 424 ? 3) Does the ReadyNAS 424 support 802.3AD link aggregation? (I have a Draytek VigorSwitch P2261) 4) How reliable is the ReadyNAS 424?, I am allways having reliability isues with SMB shares shared via UPnP on my Asustor NAS box to my Denon network audio streamer that is part of my Hi-Fi. Sometimes it works fine, othertimes my Denon network audio streamer cannot see the shares on my Asustor NAS box! (All hard wired, no Wi-Fi or Mains LAN senders) 5) Does the ReadyNAS 424 support share/folder encryption what has to be unlocked by a password on starting the unit up. (In case the unit gets stolen.) Also, below suggests that ReadyNAS OS6 supports DFS, what I thought was a proprietary technology to Windows and was not available on Linux based NAS boxes? https://kb.netgear.com/23090/How-do-I-use-DFS-feature-on-the-ReadyNAS-OS-6-storage-system Lastly , anythoughts on the ReadyNAS 424 in general? Regards: Elliott.Remove inactive volumes to use the disk Disk #1,2,3,4,3,4 after updating to 6.9.0 Ready Nas 204
Hi Everyone, This is my first post here so forgive any newb things i might say... So i have had my nas system for a little while now and i have all 4 bays filled up and I havnt added any drives to it in a while. I mainly use it as a media server for plex so although its not life or death to lose everything it would for sure suck to lose all the data i have aquired over many years. Withou pulling any drives out currently I believe them to all be WD Red. I did a bit of looking in this forum before posting and found some people with similar issues but none really have any solutions yet. I dont knw much about how to read the logs but I did try yo follow along with what some of you were suggest to other people and i didnt see any drive errors in my logs but i can supply them if needed. So The other day i watch watching something from my plex server and it said the serve went offline and when i looked the nas was still connected but the plex app was turned off. I couldnt get it to turn back on. I noticed there was an update for the app so i attempted to install it but it kept coming up with an error and i couldnt figure it out. I had been puting off the nas OS 6.9.0 update for a few months now because last time it made my nas resync and it took almost a full week but I decided to just go ahead and do the update and it appeared to go smoothly but now I get this error message and Im not sure if it always showed 2 volumes on the left hand side or not but im not sure whats going on or what to do. I attempted to remove drive 1 and re insert and it took 2 days to resync but it didnt change anything. I can try the beta 2 release but then I wont have the option for netgear paid support. I dont really want to have to pay for support but I also just wan this fixed and hopefully not lose any data and if possible know what caused it to hopefully prevent it from happening again. Any Ideas??? Sandshark StephenB Skywalker Thanks in advance.958Views0likes2CommentsNot Secure | https://xxx.xxx.x.x/admin/ Using a ReadyNAS 2100
Hello, I am using Chrome and when I go to log in my 2100, I get "Not Secure | https://xxx.xxx.x.x/admin/". I have concerns that something is wrong and I do not know how to correct my problem. I also get a message "Your connection is not private" and offers to go back to safty or proceed to xxx.xxx.x.x(unsafe). My System: Windows 10 Pro on all computers My Network: 3 Desktop computers and 3 laptop computers using a Netgear ReadyNAS 2100v2 Desktop computers are cabled and the laptop are wifi All software is upto date ReadyNAS: firmware version 4.2.30 Any help on my concerns would be greatly appreciated. Thank you Bob Merritt7.2KViews0likes2CommentsReadyNAS Pro Pioneer - Solutions Please - Bad controller?
Ah the most dreaded topic. I've gotten a bit complacent since it's been so reliable, I double back up but not everything :( and of course I need it sigh. So I shut my pro pioneer down to replace the battery in the UPS it was connected too. Now it won't power up! I figure no big deal, I have a 550w power supply lying around, I'll just plug it all together to get it running again. I get the wiring all sorted out and the power supply keeps tripping out. I tested no drives plugged and it still trips out. I tested with the 3 molex disconnected and it looks like it boots ok (I didn't bother going very far with it) I tested individual molex and it looks like only the top one is ok that doesn't trip the system. the bottom two make power supply trip out or something. I guess bad controller? Anything else I should try? what are my options? Thank you for your timeSolved6.1KViews0likes20CommentsRN526X with 6x 4TB WD Red PRO. What should I set up this time, my 3rd readynas.
This was a bit unscheduled since I was thinking to just upgrade my pro pioneer drives! However, the pro pioneer appears to have died and I think it's the raid controller causing things not to boot.... Anyhow. So I await my rn526x tomorrow to hopefully see my pro pioneer data to pull off the drives. Also I've found a good enough deal for me and bought 6x 4TB WD Red Pro drives. Historically, I always max out all the bays and never change it. My readynas NV+ still runs as a double back up of important files from my pro pioneer. The pro pioneer was a huge upgrade from my NV+ and I maxed out the drive bays with 6x2TB RE4-GPs... Both times I just went with xraid cause at the time all the talk about best flexibitily and what not I guess. I've been reading some topics here but feel I need to ask for myself :) This time, what should I do... don't bother with xraid? go straight to raid 10? There seems to be some controversy in the forums about raid10 speeds but not sure if it's still applicable today. It's highly unlikely I'll be playing with individual drive sizes, I like to set it and forget it... I was going to replace all the drives in the pro pioneer but the box unexpectedly died. I use it for storage and I while I did dabble with iscsi on the pro pioneer for VMs I didn't really stick with it and opted for raid 0 arrays on local machine. Would probably like to revisit iscsi and hyper-v again on this new nas. Thanks for your thoughts.5KViews0likes7CommentsHELP!!! Deleted a User and I Lost my files!
So I am a mac user, but I recently bought a gaming PC to use just for games, I use my ReadyNAS to hold media that I watch on TVs with have mac minis which are HTPC Anyways, my computer came with Windows 10, and as Ive seen in the forums its very difficult to get windows to see and access the files. I had 2 accounts on my ReadyNAS - admin and Server Because Win 10 kept rejecting my username and password, I thought maybe if I deleted the user "Server" and add it back in it might accept the credentials. However when I did this, a huge amount of files disapeared. I was holding those files in \\ReadyNAS\home\Server I hooked up my drives seperatly to a program thats used to recover files. I can see all the files Im missing, however I do not know how to hook up all 6 drives to my PC which I need to do in order to recover those files The files are mostly pictures, my media was not in the same folder thankfully. However those pictures have the birth of my son and wedding, Im stressing!!! How can I get access to these files back, I know theyre there I Can see them in Recaime (a program for windows that I used) Surely there is something I can do to get those files back without losing themSolved4.7KViews0likes11CommentsReadyNAS 104 Help Needed - Uninstalled App and cannot access GUI/Manage device
Hi All, I'm hoping somebody can help me here. A couple of months ago I realised I was no longer able to access the GUI of my ReadyNAS anymore to configure the device. I remember the night before both uninstalling an app at some point and also installing a new firmware when prompted. I can't remember nor am sure which has caused the issue. Since then though I can't connect to the Netgear GUI at all. I can however browse the shares from all devices. I can also use RAIDAR to discover the device, but when I try to use any of the features to gain access I get prompted for a username and password - my original username and passwords do not work anymore so I can't seem to do any more. I tried SSH as found at the below link but it didnt work. https://community.netgear.com/t5/Using-your-ReadyNAS/Can-t-access-web-GUI-setup/td-p/927583/page/2 Please can somebody offer some help and advice so that I can get my NAS up and running again please? Many thanks Matt2.3KViews0likes1Comment
