Parental Control
7 TopicsAC1750 - Genie Parental Control Fails Checking Firmware, OpenDDS working. Wifi Not, Cannot Disable
Hi, Scan topics and have not found solution. AC1750 and Genie Issue, Win10 Pro, Enabled Parental Controls, created OpenDNS and appears all appeared well execept WIFI devices not accessing internet. WIFI devices have connection reported by AC1750 console and Genie. Genie version is 2.4.54, AC1750 is V1.0.1.38_1.0.25 So Trying to reset, undo, DNS via AC1750 Web console. Won't allow modifications without disabling Parental Controls. VIA Genie, appears all menu selections working EXPECT depressing Parental Controls results in failed Checking Router Firwmare, check internet connection.... Thus cannot get past this to disable Parental Controls to reset dns settings to get back to orignal configureation before I let the "genie out of the bottle" Cannot change AC1750 DNS settings to undo OpenDNS settings. Don't want to reset AC1750 due to rules, vpn, vlan settings. So 0) Symantec Endpoint firewall disabled. 1) Ethernet Connections working fine with OpenDNS filtering. 2) Genie will not get past detecting router via Parantel Controls. 3) Wifi Not connecting to internet or to AC1750 web console. WiFi Adapter DNS = 208.67.222.222 , 208.67.220.220 4) Web connection to AC1750 shows all PC and Wireless connections active 5) Netgear Genie Shows Network Connections, Wifi connections, router firmware vesion. 6) Genie > Router Settings > returns V1.0.1.36 as expected. Ideas?2.3KViews0likes3CommentsParental Control Totally Failing
My new router does not filter ANYTHING on the internet for parental controls. I have selected "Moderate" and then customized even more and if I type in very explicit nudity or other sites they freely come up. Am I missing something? I have an openDNS account and parental controls are enabled and saved for "At All Times" Funny, my model doesn't show up at all on this community Nighthawk R8000P, firmware V1.3.0.8_1.2.1SolvedParent control not working (not blocking anything)
I bought Nighthawk(R) X4S R7800 and struggling to get Parent Control working for me. Firmware(v1.0.2.28) and Genie (v2.4.38) are latest versions. I tried forums but could not find much help. Here is what I followed https://kb.netgear.com/25687/How-do-I-configure-Live-Parental-Controls-on-my-NETGEAR-router-using-the-NETGEAR-genie-app Netgear genie says that live Parental Controls are enabled and Filtering level is high. OpenDNS account is also shown properly. I am not using any bypass account as of now. Router is at 192.168.1.1 Router / AP / Bridge Mode ==> Router Mode Internet Setup is showing 208.67.222.222 and 208.67.220.220 as DNS servers OpenDNS forum said that LPC and OpenDNS are not compatible and only one should be used. So in opendns, I checked and found no network configured. Also I have restarted everything. Mobile, Laptop and Router few times. Issue: Facebook or adult sites are not blocked on any of the devices that I used. It does not matter if I connect to 2.4GHz or 5GHz. Why am I struggling to configure this simple thing. As I followed the guide, I am thinking that this feature is just broken in Netgear Router or some setting is missing. Here is the output of some commands ipconfig /all Wireless LAN adapter Wireless Network Connection 4: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7260 #2 Physical Address. . . . . . . . . : ----------------------- DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.1.12(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, August 04, 2017 7:54:05 AM Lease Expires . . . . . . . . . . : Saturday, August 05, 2017 10:24:51 AM Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 192.168.1.1 NetBIOS over Tcpip. . . . . . . . : Enabled nslookup -timeout=12 www.facebook.com ------------- Server: UnKnown Address: 192.168.1.1 Non-authoritative answer: Name: star-mini.c10r.facebook.com Addresses: 2a03:2880:f126:83:face:b00c:0:25de 31.13.78.35 Aliases: www.facebook.com nslookup -timeout=12 -type=txt which.opendns.com. 208.67.220.220 ------------------ Server: resolver2.opendns.com Address: 208.67.220.220 Non-authoritative answer: which.opendns.com text = "I am not an OpenDNS resolver." opendns.com nameserver = auth3.opendns.com opendns.com nameserver = auth1.opendns.com opendns.com nameserver = auth2.opendns.com auth3.opendns.com internet address = 208.69.39.2 auth1.opendns.com internet address = 208.69.39.2 auth2.opendns.com internet address = 146.112.60.53 Please help, I am stuck.Solved23KViews0likes10CommentsC7000 Nighthawk Parental Control not working by specific device
I have the C7000 Comcast cable modem router and have the genie app installed on my mac and iphone 6plus. I can set the global parental control for any user through opendns but I am not able to set configure device specific web content filtering from the network map in the genie app. The app shows the device is configured to high to block video sharing but I'm still able to get to youtube and espn. Anyone solve this?4.4KViews0likes3CommentsCan I manage Parental Controls for devices via the Network Map?
I have the R6400 model and would like to centrally manage access to all devices? i.e., the hours of access for devices on router? Can this be done? OR do I need to install genie app on each device and apply Bypass account?3.4KViews0likes1CommentCan I disable parental control directly thru routerlogin because genie has an error on opendns?
Can i disable parental control if i log directly to the router using routerlogin? I always get an error when using Genie. I need to disable parental control to be able to update my DNS to fix another issue, access to some sites. Really hope to hear from the community soonest. Thanks,2.7KViews0likes1CommentDesktop Application Netgeargenie will not except any password attempts
I can access my router through the browswer no problem!!! My modem was replaced due to faulty previous one. When I launch the Desktop Appliacation Netgear Genie no password will work. I have tried an previouse parental control password ... no good Tried default and no good Tried the one on the router ... no good I have searched the hard drive trying to find where password might live to no avail. I have a teenager in the house and trying to limit access and access times .... Nothing works and the browser version does not give me parental control rights. Dan4KViews0likes8Comments
