intermittent,factory,reset
1 TopicHow To Hard Reset a GS108Tv3 Switch
I have a GS108T v3 switch that doesn't configure itself at 192.168.0.239 when it's connected directly to a MacBook, nor do I see any DHCP requests coming from it. If I put it on a network with a DHCP server I still don't see any DHCP traffic or its MAC address in the servers leases. So, I'd like to try a hard (factory) reset to see if it will come back to life. Since I can't use the GUI without an IP address for it, is there another way to do a reset?147Views0likes5CommentsCannot access GS110TPP after reset
I purchased a used GS110TPP which I need for its PoE features and performed a factory reset by pressing the reset button on the front panel for more than 5 seconds. I expected to be able to access the switch on http://192.168.0.239 or at least to be able to ping it. However, I was not even assigned a DHCP address, so my computer got a 169.254.x.x self assigned address. I then set my own address manually to 192.168.0.240 (netmask 255.255.255.0, according to the manual), but still cannot access the switch. Is there anything else I can do? I performed multiple resets with different times of pressing the button (below 2 seconds, below 5, over 5, over 10, over 20). Kind regards JohannesSolvedTrying to change the name of my router on the extender
This is frustrating. I have a new router (R7000). It has a new name and password. There are 2 speeds on the router, The 5G speed still has the name of the old router, however it connects with the password of the new router. I wanted to correct this by logging into the extender. I don't know the password to the extender access. So... I'm on the "Extender Password Recovery." I got to this by putting in the serial number of the EX6100. Now it wants me to answer two security questions. I answer the questions -- they are not answers that I don't know --- my sister's first name, my father's middle name... Then I get "The information you entered does not matcch what is saved on the routher." AFAIK I've never given this information to my (R7000) router!! I might have given it to the extender... when it was connected to the old router... Is there anyway to completely reset this extender?Intermittent connection problems
I am looking for help diagnosing intermittent connectivity issues with my CM1000 modem. I am not sure what clues I should be looking for and I have not been able to detect any patterns to indicate cause. Let me offer some details… I am an Xfinity customer in my home, and I have been using a Netgear CM1000 modem for around 6 months. Everything worked great for the first 5 months. However, the last month I have been getting hit with maddening intermittent connection problems. I lose all internet connectivity and cannot ping anything on the internet for short periods of time. These issues usually just last a minute or two, but sometimes as long as 5 minutes. Network connectivity eventually comes back without any intervention from me. Some days I have no connectivity issues, other days it happens several times (usually in the most in-opportune times!). I have not noticed any change in the modem lights when this occurs. When I call Xfinity/Comcast support their only suggestion is to reboot the modem. That usually causes the connection to be restored, but I don’t think that is really fixing anything – like I said the connection issues usually only last a minute or two anyways. The agent I talked to at Comcast said she cannot see anything else on her end. Since I own my own modem, she stated it will likely cost me money to have a tech come out and look at it. Before I break down and have someone come out, I wanted to search for some evidence that is or is not a modem problem. I’m not against buying a new modem either, but am going to be frustrated if I have the same problems. This behavior occurs on multiple computers - both wireless and wired – which leads me to believe it is a network issue. I swapped out my router for a few days just to see if it was possibly a router issue. The same issues occurred with the replacement router, so I think I can rule that out as well. I did chat with my good friend Google a bit and learned to check the power levels. The power levels seem ok as they fall between the -7 to 7 range for downstream and 38-48 for upstream. I haven’t touched any cables lately, but did double check the cables I had access to to make sure they were connected tightly. My Hardware version is 2.02 and firmware version is V3.01.04. I understand that Xfinifity/Comcast controls pushing out the firmware updates so there is not much I can really do about adjusting firmware. I do have an older (slower) modem I suppose I could go back to for a while and see if I have problems with that. Any thoughts/ideas would be appreciated.1.5KViews1like1CommentReadyNas DUO 2110v2reset network config ONLY
I am not sure if the ReadyNas Duo has static or DHCP. I want to reset admin and/or network settings (I can guess passwords if I can connect at least). However, I do not want to destroy data. Is there ANY way to connect and see the current IP settings? It's not showing up on DHCP so I believe it's hard coded to a 10/8 subnet ip. I have forgotten what it would be though. Thank you in advance.Solved2KViews0likes3CommentsCG3000D will reset but network remains password protected
I bought this router used and pushed the factory reset button when I plugged it in. It shows factory SSID but it’s password protected! I can not login to my network to make changes. I then held the factory reset button for 30 seconds and then disconnected power and plugged back in and my SSID is now 000000 still password protected. Help!1.2KViews0likes1CommentReadyNAS "Admin Page" is offline
Upgraded to firmware 6.7.5 through the web interface and now the unit is not responing via the browser at all. SMB share is still working Tried Rebooting Tried Reset via reset pin on back and selecting OS Reinstall - same issue Raidar Diagnostic will not connect, but raidar says unit is healthy ! I cannot download the logs because login is not working, I know the password before someone suggests password recovery. Looking at USB recovery but cannot get the tool to recognise any firmware to make a usb for me. Format USB to Fat32 and put these in root Reboot machine and hold backup for 30 seconds. Machine says booting from usb, then after a few minutes, resets and does FW Upgrade. But the firmware is still 6.7.5 ?? How to do it? What am I doing wrong? I know the issue is network adapter related because "\\192.168.1.101\folder" is working fine, but "\\192.168.1.147\folder" comes up with network error do i want to diagnose? If I factory reset it with different disks in it, can I the set it to x-raid and put back the original disks without losing data? Will factory reset put the original firmware back in or will it use 6.7.5 ? I really want to get this working again :( Many thanks for any help6.5KViews0likes26CommentsR6100 w/ no active LAN ports, after reset, can I access router wirelessly
I have full use of the WIFI aspect of my R6100 router. None of the LAN ports work w/ any of my devices (TV, desktop, laptop). I use both frequencies, 2.5 and 5, and both work w/ my devices. I've done the WAN to LAN port test and get blue and amber LEDs lit up, so I guess the LAN ports are "active". I've unplugged modem and router, multiple times and still have same situation. I'm left w/ doing a reset to default settings. If I do that, and the LAN ports still don't work, (making hard wire router setup impossible) will I be able to access the router wirelessly to re-set my security settings? I'd still like to be able to use the WIFI function while a wait for a new router to be delivered. Sorry if this is a foolish question, but I don't want to be left stranded for a few days by doing the reset. Thanks allSolvedOrbi WiFi System performed a hard reset to factory defaults overnight
I got my orbit set up on Sunday. Everything was working well until Tuesday morning. When I woke up Tuesday morning my SSID had changed back to ORB20. Tried to logon with my password, didn't work. All my settings were gone, a factory reset had taken place overnight. Check with the family and no one played with the system. Any idea how a factory reset and happen 'spontanously'? RBR50 Firmware V1.10.1.2 Operation Mode Router
