rs600
35 TopicsHave you seen this about Netgear RS Routers? Pretty interesting and maybe scary or even dangerous!
Supposedly there is a Backdoor to our Rs Series routers by sending magic packets? This makes me nervous as I work and live behind a RS700 in my house. It sounds pretty serious? Gamers Nexus "There's a Secret Backdoor in Netgear" Routers, ft. Wendell of Level1 Techs https://www.youtube.com/watch?v=3NIXvqtVWso Level1Linux Wi-Fi 7 routers are a Mess, So We Built a Local AI Test Harness (tp-link and netgear FAILED) https://www.youtube.com/watch?v=xfRty0k_yRs Level1Techs Netgear Was Right About TP-Link. Unfortunately, Netgear Is Worse. https://www.youtube.com/watch?v=IfOgnDTRmnA&list=WL&index=1&t=324s You guys think this is being paranoid or is this a real problem? The guy from Level1 said hed never use a Rs700 as a home Router? I'd Love for Netgear to read this and respond to us!!197Views0likes4CommentsNETGEAR WiFi 7 RS600 and 320 MHz
Hey Friends, I just bought the NETGEAR Nighthawk Tri-Band WiFi 7 Router (RS600) AND a MacBook Pro with the M5 Pro chip that supports WiFi 7. I have my 6 GHz network set up but I don't see any of the 320 MHz channels. My region is United States. What am I missing? :-)Solved205Views0likes4CommentsRS600 latest version, 1.0.6.16 IoT network works like a Guest Network
Well, I got all excited about the new IoT network capabilities in 1.0.6.16. I moved a couple of devices to the new IoT network, and they connected to the internet. Then connected my phone to the IoT network. It also connected to the internet but could not connect to the devices. Works no different than a guest network. Then switched everything back and working fine. What a waste of time and emotion.1.3KViews1like43CommentsSetting RS600 Router
Recently purchased a RS600 router. Followed the instructions that came in the box with the router. And still unable to get the internet. I connected the computer to the modem and could get the internet, but when connected to the router, no internet. Using the nighthawk app, doing the startup check, it says the cable is connected, but no internet connection. I did this several times with no success. And how can use the routerlogin sit to manually log in if I cannot create/join the network?146Views0likes4Comments
