Frankss's avatar
Frankss
Guide
Aug 24, 2026
There is an issue where hidden networks are automatically enabled in AP mode
I use codex to analyze the source code
The firmware uses several overlapping state systems, including the NETGEAR config database, Broadcom NVRAM, temporary files, and hardware partitions. Features depend on multiple settings such as:
ap_mode
i_opmode
modetect_state
mesh_support
mesh_created
When these values become inconsistent, unexpected behaviour occurs.
Confirmed Issues
- AP mode automatically enables hidden 5GHz and 6GHz Mesh backhaul networks even when no satellite is configured.
- The device can report conflicting states:
i_opmode=apmode
modetect_state=Router
mesh_support=1
- /etc/init.d/br-mode uses $CONIFG instead of $CONFIG, breaking the intended AP-mode check.
- Bridge-mode startup and shutdown use different state files:
/tmp/enable_br_mode
/tmp/br_mode_enable
  • FURRYe38's avatar
    Was believed at some point the NG would introduce MESH features to the RS series. I believe this was side lined and was no longer being worked on.
    Are you seeing this hidden network coming from your unit?
      • FURRYe38's avatar
        THe network is locked and not accessible to anyone. Same for Orbi systems. Seen there as well however only used by the wifi system and not accessible to users.
        Its possible NG has forgotten to disable it in the RS FW.
  • FURRYe38's avatar
    NG is aware of this item. Hidden SSID network will be remove upon next FW update.
