Dortmonster
Aug 13, 2020Initiate
Disney+ Won't Stream Through Orbi Router
I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular cable modem router it works. I tried deleting Circle thinking that might be blocking it, but that didn't work either. Has anybody else seen this issue and is there a solution?
- MstrbigMaster
Dortmonster wrote:I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular cable modem router it works. I tried deleting Circle thinking that might be blocking it, but that didn't work either. Has anybody else seen this issue and is there a solution?
Have you changed any settings, modified your network, updated your virus protection etc, in any way? What are the actual symptoms of Disney Plus?
- MstrbigMaster
As a followup, I just installed Disney+ on the rest of my home TVs, ands streaming devices. With a standard Orbi setup, with no modifications, except some UPNP camera settings, Disney+ plays perfect on all devices, even one that I had to side load the app on.
- DortmonsterInitiate
I have not modified any of the system settings prior to this occuring and there hasn't been any virus updates to my knowledge installed.
The error i am getting when trying to stream on Disney+ is an "Opps something went wrong" error when i try to play a movie. I am able to get into Disney+ and navigate around to all the menus and make selections to play movies, but it just won't play the video.
- MstrbigMaster
Unless you are blocking something, Orbi acts like any other router, mesh system and would not, by itself cause this issue.
What device are you using for Disney+? It could be the device. Try resetting the device. Also, I have an android box that I downloaded Disney+ app. It won'y play movies. Support told me their app is not compatible with the version of andriod I have and I would need to update. Unfortunately there is no update. I'm menbtioning this as this could be your problem as well.
- VkrishAspirantI am having the same issue ie Disney+ not working on orbi.
- MstrbigMaster
Vkrish wrote:
I am having the same issue ie Disney+ not working on orbi.I can confirm Disney+ plays through an Orbi device. Not sure why yours doesn't. What device are you using for Disney+? My Disney+ is streaming through 3 Samsung TVs, 1 Vizio TV and Amazon Firestick with no issues. I earlier mention it would not work on my Android box, but it now does as well. All my devices are wireless through an Orbi RBK53 system.
- FreewayAspirant
Just want to add my voice. I am using latest firmware 2.5.2.4 for RBR50 and both satelites (RBR50S). And, I cannot get my firestick TVs nor android telephones to connect to disney plus thru the wireless portion of ORBI either. I CAN connect to disney plus using the wired network on my computer when it is plugged into the back of the orbi. And, I can connect to disney plus when using mobile data (off the orbi wireless network). I have no parental controls enabled on the ORBI wireless network. Netflix, Hulu, etc. all work fine. Disney plus and a few other select apps simply will not run through the ORBI wireless network for me. So, please continue to share whatever solutions you may have.
Spectrum Cable Internet. CM500 cable modem. Orbi Mesh WiFi. DLink 18 port switch (unmanaged).
- billaschGuide
I am having the same problem, I found this thread where NetGear support changed settings and got it to work, but I am completely screwed right now.
Does anyone know how I can fix my Orbi to allow me to see DisneyPlus? I would hate to have to buy an ENTIRELY new mesh network to solve this...or to pay for a VPN service. sigh*
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/true- FURRYe38Guru - Experienced User
billasch wrote:I am having the same problem, I found this thread where NetGear support changed settings and got it to work, but I am completely screwed right now.
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/true- billaschGuide
FURRYe38 wrote:What Firmware version is currently loaded?
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/trueFirmware: v2.5.2.4
MFR and Model of ISP modem: Xfinity - Technicolor CGM4331COM
- sandthipeAspirant
I was having the same issue with a Netgear Nighthawk MR60 Mesh router. I was able to resolve the problem by using Cloudflare's DNS for IPv4 and IPv6. This will probably work with other custom DNS providers like Google or OpenDNS. Cloudflare DNS info: https://1.1.1.1/dns/
IPv4
- Setup -> Internet Setup
- scroll to DNS section and select "Use these DNS Servers"
- 1.1.1.1 for primary
- 1.0.0.1 for secondary
- Apply changes, wait for reboot
IPv6
- Advanced Setup -> IPv6
- scroll to DNS section and select "Use these DNS Servers" (depending on your IPv6 "Internet Connection Type" you may not have this option)
- 2606:4700:4700:0000:0000:0000:0000:1111 for primary
- 2606:4700:4700:0000:0000:0000:0000:1001 for secondary
I'm not sure why this works, but my guess is that it has something to do with the way certain ISPs use a deprecated method for "converting" IPv4 traffic to IPv6.
