CMYK's avatar
CMYK
Tutor
Apr 21, 2018
Orbi Periodic Slow Wired Connection to Satellite
I have a PC (1 GB ethernet) connected by Cat5 cable to a RBS50 satellite. Periodically (every couple weeks), the download speeds drop from 70 Mbps (this is max - it's what we pay Comcast for) to 3 Mbps. Upload speeds remain unchanged at ~8 Mbps (also what we pay Comcast for).
Other devices connected by wifi are not impacted.
Unplugging and plugging back in seemed to fix the issue. I've tried different ports & cables. Any ideas on what to do next?
  • FURRYe38's avatar
    Do other wired devices see similar issue if you have a spare PC or laptop to test with?
    What is the Mfr and model of this PC?
    What is the Mfr and model# of the ethernet adapter card in the PC?
    What FW are you using one the router and satellite?
    • CMYK's avatar
      CMYK
      Tutor
      Firmware is 2.1.3.4 for both router and satellite.
      PC was self-built a couple years ago (i7-5820K); the motherboard is MSI X99A SLI PLUS ATX LGA2011-3.
      This wasn't an issue with the EX7000 that the Orbi replaced, so I don't think it's a hardware issue with the PC.
      I do not have another laptop to test wired connection speed (no ethernet ports on our laptops), but I will try to figure something else out.
      • FURRYe38's avatar
        Was a factory reset performed on both router and satellite after updateing to v2.1.3.4? Try this. A reset is needed on this version...
  • FURRYe38's avatar
    Ok.
    Just curious, what is the Mfr and model of the ethernet card in this PC?
    • CMYK's avatar
      CMYK
      Tutor
      Ethernet is in the motherboard (model number above). The chipset uses an Intel I218 Gigabit LAN.
      • FURRYe38's avatar
        Yes, was looking for the chip set Mfr of the ethernet adapter on the motherboard.
        Thanks
  • I have the exact same issue with an RBK22 satellite and cat6 wired connection.  Firmware 2.1.4.16 on Windows 10.
    I purchased and set up yesterday, plugging into port 2 on the satellite.  I was getting about 400mb down, 40mb up consistently.  I booted up my PC today and started getting about 3mb down, while still getting 40mb up.  Rebooting the router and satellite did not help.  I plugged into port 1 and everything is back to normal.
