A1406's avatar
A1406
Tutor
Mar 10, 2021
Orbi RBR50 intermittently dropping internet connection
Hello,
I am having issues with my RBR50 intermittently dropping our internet connection. It seems the router might be restarting at what seem like random times causing a WiFi disruption. I've looked into the logs, but a restart also seems to erase all log entries prior to the restart. The connection is restored after the RBR50 reboots. I updated the firmware to the most current version (2.7.2.104) and this did not fix the issue.
Any advice on how to continue troubleshooting?
    • A1406's avatar
      A1406
      Tutor
      vajim wrote:
      Get rid of 2.7.2.104
      lots of problems
      The issue occured prior to the firmware update, so while that could be contributing factor, it's likely not the root cause.
      Or is there a way to confirm it's the firmware causing the issue? Is there a more stable version I should download and apply? Does netgear even give access to previous firmware versions?
      • vajim's avatar
        vajim
        Master
        A1406 wrote:
        lots of problems
        Go to the download section here and enter your model number.
        do a search here on 2,7.2.104.   Lots of complaints
  • CrimpOn's avatar
    CrimpOn
    A1406 wrote:
    Hello,
    The problem was happening before firmware was updated to 2.7.2.104?
    It would be useful to confirm whether the Orbi is (a) dropping the network connection, (b) the Orbi is restarting, or (c) the Orbi remains on line but has quit providing WiFi.
    • When the Orbi restarts, the Orbi log is reset (empty), whether it restarts by itself or the user restarts it (power switch, reset hole, etc.) Can you look at the Orbi log file before attempting to restart the Orbi yourself?
    • If only the internet connection has dropped, then devices should continue to connect to the Orbi WiFi, but be unable to "do anything" on the internet.
    • If the internet connection remains good, but WiFi has dropped, then a device connected to the Orbi with ethernet should continue to function correctly.
    If the network connection is dropping
    • A1406's avatar
      A1406
      Tutor
      CrimpOn wrote:
      A1406 wrote:
      Hello,
      Yes, this was happening before updating to 2.7.2.104.
      Agreed, what you're proposing makes sense. My sense is that it is (b), but I am not yet 100% sure.
      • Yes, I can do that. What information would be useful that I can provide?
      • I believe I am losing connection to the Orbi and it is not that the internet connection has dropped.
      • I have some home entertainment peripherals hardwired to the Orbi, but so far this has only occured while I am working on my laptop which is connected via WiFi (which drops when the issue occurs).
  • FURRYe38's avatar
    Please try a factory reset and setup from scratch with the RBR and RBS.
    https://community.netgear.com/t5/Orbi/RBR50-Have-You-Installed-V2-7-2-104/td-p/2055212/jump-to/first-unread-message
    A1406 wrote:
    Hello,
    • A1406's avatar
      A1406
      Tutor
      A1406 wrote:
      Hello,
      I have fiber optic service through Sonic and the modem was installed in a way where I cannot see the mfr/model#. I will have to reach out to them for this info.
      I will try a factory reset and setup from scratch.
      • FURRYe38's avatar
        Ok, only checking to see if there is a router at the modem or not. These can be problematic.
        Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
  • FURRYe38 CrimpOn
    I havn't yet had a chance to factory reset and re-setup the RBR50, but something happpened last night that could provide some insight.
    I was playing Xbox (which is hardwired to the RBR50) and the internet connection dropped/I was disconnected. The RBR50 LEDs then went to solid white, stayed solidly lit for a bit, then went to pulsing white. The connection was then reestablished.
    Does the fact that a hardwired peripheral lost connection and the LED info/behavior provide any clues?
    • vajim's avatar
      vajim
      Master
      if you're still running 2.7.2.104 it might
    • FURRYe38's avatar
      Were you able to find the brand and model# of the ISP Modem the RBR is connected too?
      Besides the xbox being connected to the RBR, is there any other wire connected devices with the RBR?
      Possible that the RBR saw a quick connection problem between the RBR and Modem and wasn't long enough to show PINK and the RBR soon recovered the connection with the modem...
      I have two xbox consoles connected to mine...
      • A1406's avatar
        A1406
        Tutor
        I have not heard back from my ISP about the modem brand and model.
        Besides the Xbox, there is an Apple TV, Network-Attached Storage (NAS) device, and a Sonos speaker hardwired to the RBR.
        Would my ISP be able to determine if this is caused by quick connection problems?
    • CrimpOn's avatar
      CrimpOn
      The Orbi log may contain a clue if there is an entry at the time of this event.
      • A1406's avatar
        A1406
        Tutor
        It looks like the log was deleted again after the RBR rebooted.
        I do see A LOT of "attacks" logged. I've seen this in the past, googled it, and found that it seems to mostly be the RBR miscatagorizing pings, but I've always been a bit uncomfortable about this. Previously the IP addressess were from Amazon. Attacks catagorized as the following:
        [DoS Attack: TCP/UDP Chargen]
        [DoS Attack: SYN/ACK Scan]
        [DoS Attack: RST Scan]
        [DoS Attack: ACK Scan]
  • Apparently it downloaded the firmware update on its own yesterday, and now I am continuously losing the internet connection. Have to reboot to get back on. Called Netgear support and told I needed to reconfigure the network on a monthly basis which would cost me a service contract of several hundred dollars or $50.00 each time. Their firmware caused the problem, and now I have to pay them to correct it? Is there a way to roll back the firmware?
    • vajim's avatar
      vajim
      Master
      Sad
      you can go to the download section above and enter your model number
      im not sure about the firmware downloading by itself.   It usually requires the user to execute a few clicks.
