nhantenna's avatar
nhantenna
Apprentice
Apr 12, 2018
Nighthawk LTE hotspot + automatic firmware nightmare
I live in the United States.  I have an AT&T issued Nighthawk LTE hotspot running on AT&T network.  For the last several weeks I have been reading this forum about automatic firmware updates occurring unexpectedly with all sorts of firmware update problems.
Here is my story.
1) I run without battery.
2) I run with Anker Quick Charger.
3) My Nighthawk has been working perfectly for months.
4) All of a sudden Nighthawk internet outage.
5) Walk up to Nighthawk device completely dark.  No LEDs.  No display.  Pushing Nighthawk button does nothing.  Has my Nighthawk been fried?
6) Power off Nighthawk.  Power on Nighthawk
7) "Updating device.  Do not power off"  We didn't know for sure before, but we know now, AT&T Nighthawks get automatic firmware updates.
8) Nighthawk goes completely dark.  No LEDs.  No display.  Pushing Nighthawk button does nothing.  No completion message.
9) Power off Nighthawk.  Power on Nighthawk
10) "Updating device.  Do not power off" What is happening?  Did the firmware fail?  I see a tiny progress bar, but it is not moving.
11) Nighthawk goes completely dark.  No LEDs.  No display.  Pushing Nighthawk button does nothing.  No completion message.  What is happening?  Is my Nighthawk firmware now corrupt?  What in the world happened?
12) Power off Nighthawk.  Power on Nighthawk
13) "Updating device.  Do not power off"  Looks like the firmware update has corrupted my Nighthawk.  I am now stuck in an infinite loop.  The progress bar looks like it has gone a bit further.
14) Nighthawk goes completely dark.  No LEDs.  No display.  Pushing Nighthawk button does nothing.  No completion message.
15) Power off Nighthawk.  Power on Nighthawk
16) Repeat above steps over and over and over and over and over again and you will notice the progress bar moves a little bit further each time.
17) "Netgear" "AT&T Logo" "You have xyz number of unread messages" Finally success right?  Wrong!
18) Nighthawk goes completely dark.  No LEDs.  No display.  Pushing Nighthawk button does nothing.
19) Power off Nighthawk.  Power on Nighthawk
20) "Netgear" "AT&T Logo" "You have xyz number of unread messages"  Now have blue LED flash to indicate connected.  Sure enough I am back up and running with forced NTG9X50C_12.02.06.00 firmware.
1) The product experience is shamefully bad.
2) The automatic firmware update process is shamefully bad.  I have been updating firmware for 30 years and have never seen anything this bad.
3) The unexpected, unplanned internet outage is unacceptable.
So many ways to improve here:
1) Let me enter my email address in the Nighthawk firmware.  Instead of taking my internet down without warning, why not send me an email telling me to take action within xyz days.  Provide me with step by step directions on how to complete the firmware upgrade since it is not normal all right there in clear language in the email.  For example, send me email 10 days out.  send me an email 5 days out.  send me an email 2 days out, etc.  Giving me plenty opportunity, notice, and education on what is about to happen.  The current lack of documentation on firmware AT&T forces on end users is banannas and obviously totally unacceptable.  How many Nighthawk units were returned to AT&T as a result?  How many AT&T Nighthawk customer ticket/calls were opened because of this?  How much end user time is wasted because AT&T did not bother to test the Nighthawk update first?
2) Let me opt out of automatic firmware updates in Nighthawk firmware.  I am not aware of any device on AT&T network that forces firmware updates by disabling the device.  If AT&T did that to people's phones there would be class action lawsuits filed the same day.
3) Need better update text on the Nighthawk display.  "Reboot 1 of 5"  "Reboot 2 of 5" "Reboot 3 of 5" etc.  "Firmware installation complete".  Anything is better than what we currently have.
  • Good afternoon!  I just joined this forum, because I had the same issue as you!  I am at&t as well.  I also run the nighthawk with NO battery.  I also bought a QC 3.0 brick to plug in because the brick that was sent with the device isn't strong enough to run wifi (which I have disabled now anyhow because I am hooked in to my Asus router via ethernet) AND data at the same time.
    I got back from Vacation last month to no internet.  I checked the nighthawk and it appeared to be off.  I know you said you saw no LED blinking, however I had an amber LED blinking rapidly...however it was so DIM and fast that if you didn't stare at it, you would never know it was blinking like that.  My unit did the same thing.  Would repeat turning "off" when trying to do the firmware update that somehow the system pushed to it and forced it to do on its own.
    I had to get the box out, put the battery in so that update would finish.  I then took the battery out.  Am I going to have to leave the battery in this thing, so it doesnt lock up with the next forced update?  Are these "lock up" boxes faulty, do we need to exchange them?  Anyone know what is going on?  I have read somewhere else about someone having the same problem....dim amber LED, etc....but I can't find it now.  I wish I bookmarked it.
    I should add my firmware date is 02/07/2018 version NTG9X50C_12.02.06.00
    It also says "last checked for firmware" on 04/01, so it is going out on its own to check for new firmware every couple of weeks.
    • nhantenna's avatar
      nhantenna
      Apprentice
      "I just joined this forum, because I had the same issue as you!"
      the nighthawk devices are carrier/location specific.  if you are AT&T United States, you should have same experience as other AT&T United States nighthawk owners.  Especially when it comes to AT&T nighthawk firmware.
      "however I had an amber LED blinking rapidly...however it was so DIM and fast that if you didn't stare at it, you would never know it was blinking like that."
      we have the same dim LED issues.  you are not alone.
      "I had to get the box out, put the battery in so that update would finish. "
      i never put the battery back in mine.  it took many reboots to get the firmware updated, but it eventually updated.
      "Am I going to have to leave the battery in this thing, so it doesnt lock up with the next forced update?"
      it all depends on the firmware update.  if AT&T firmware is going to take your nighthawk offline, it does not matter at all whether your battery is in or not.
      "Are these "lock up" boxes faulty, do we need to exchange them?  Anyone know what is going on?"
      Let's start with the nighthawk community first?  Any nighthawk owners out there comment on their forced firmware updates?
      1) Did the firmware automatically update without any user intervention?
      2) Did you have to manually reboot the nighthawk?
      3) Did you have your nighthawk battery in or out?
      Then on to netgear reps.  ArodiD Any comments on multiple reboots to get forced firmware to install?  Is that normal/expected?  How should the forced firmware installation work?  Right now users are walking up to Nighthawks that have no lights and the Nighthawk button does nothing.  That is a bad way to start the firmware update process.
      nhantenna
      Apprentice
      "so it is going out on its own to check for new firmware every couple of weeks."
      the forced firmware problems will continue unless AT&T/Netgear changes how the process works.  AT&T/Netgear can and will take your Nighthawk offline at any time they please with no warning.  If you have it at a vacation home, use it for security/alarm systems at a business, use it in other places you can not quickly get to, you are out of luck.  once nighthawk users have one or two bad experiences with the forced firmware problems, they will stop using the nighthawk.
        nhantenna
        Apprentice
        Then on to netgear reps.  @ArodiD Any comments on multiple reboots to get forced firmware to install?  Is that normal/expected?  How should the forced firmware installation work?  Right now users are walking up to Nighthawks that have no lights and the Nighthawk button does nothing.  That is a bad way to start the firmware update process.
        ArodiD DarrenM can anyone from netgear respond?
  • @JasonN Blanca_O I am following up on this thread.  This thread is 63 days old without any technical response from Netgear.  Please escalate.
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi All,
      Please be informed that NETGEAR and AT&T are working on a firmware. We will provide update once new information will be available.
      Blanca
      Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi All,
      We just had a new firmware certified by AT&T that should fix the issue. Please log into the MR1100 UI and check for an update to get the latest firmware.
      The FW should NTG9x50C_12.02.06.01 and PRI should be 2.15
      Please provide us feedback once you have the lastest firmware installed.
      Blanca
      Community Team
      • shizam76's avatar
        shizam76
        To be exact, what is the firmware fixing? It will no longer do updates on its own?
      nhantenna
      Apprentice
      JasonN Blanca_O
      Firmware levels on my Nighthawk:
      Hardware Version = 1.0
      PRI Version = 02.15
      Firmware Version = NTG9X50C_12.02.06.01
      Bootloader Version = NTG9X50C_12.02.06.01
      GUI Version = MR1HDATA_04.01.55.02
      Firmware Build Date = 2018/06/07
      • Blanca_O's avatar
        Blanca_O
        Hi nhantenna,
        Thank you for providing the requested information. Let me check this with the team.
        Blanca
        Community Team
  • nhantenna Blanca_O shizam76 JasonN: I reported the same problem back in January in this post. As you'll see, I found that I needed the battery installed for the automated firmware update to proceed. On Friday (6th July 2018) the same thing happened again. I lost internet connection via my Ethernet connection to the M1 (with intermediate Ethernet switch) and when I investigated this, I found that the M1 had no blue or amber flashing LED - it appeared to be down. I tried tapping the power button to no effect. I removed the power cable (USB C to Anker QC 3.0 charger) and then plugged it back in. The M1 LCD screen indicated that there was an update in progress, displaying a progress bar. Seconds later, the M1 went dead again. Having experienced this behaviour previously (see above linked post), I put the battery back into the M1 - this was already charged to around 80%. The LCD screen then displayed the update in progress message with progress bar. The latter didn't move smoothly - between intervals of what seemed like minutes, it jumped to new positions. The M1 appeared to reboot a couple of times and finally, the progress bar reached 100% and the upgrade was successful.
    My provider is EE in the UK. The updated firmware and bootloader are now NTG9X50C_12.04.02.0.0 with a build date of 2018/06/07. The GUI is now MR1100-100EUS_04.01.67.00. The new features include the option to disable Ethernet Standby, which would otherwise occur after 2 minutes of Ethernet inactivity. Arlo support is also added.
    Prior to the update, my firmware was NTG9X50C_10.22.03.00 with a build date of 22nd Nov 2017. Comparing these version numbers, it looks like EE customers in the UK have probably missed out on a few intervening firmware updates, but it's impossible to know exactly what's going on because Netgear still haven't bothered to publish change logs / update histories to support their customers more effectively, as I requested back in January in this post. So much user frustration could be avoided by COMMUNICATING with your customers in an upfront, timely manner - tell people what you're about to do and give precise details of what bugs have been fixed and what new features have been implemented. This will inevitably result in happier customers and increased sales. It's a no-brainer - I'm just astounded that you aren't getting this message NETGEAR.
    • TeeJay74's avatar
      TeeJay74
      Virtuoso
      All known problems now fixed with latest firmware 12.04.02.00, PRI 04.03. EU-version users should get this update early next week, hopefully on Monday. I see this very important update.
      • UK-based's avatar
        UK-based
        Luminary
        Thanks TeeJay74 for that reassurance. The firmware update that occurred on Friday in my M1 is 12.04.02.00 but the PRI version is 03.03. Does this mean that there will be another firmware update next week, possibly tomorrow?
        While it's reassuring to be told that all known problems are fixed, you appear to be in a priviledged position, doing test work for Netgear and probably being made aware of all current issues and fixes. The general public are sadly not kept informed of upcoming and past bug fixes and also new features. As I've said in a previous post, we're treated by Netgear as mushrooms - kept in the dark and fed on you know what...
  • Blanca_O I am following up on this thread.  This thread is 91 days old without any technical response from Netgear.  Please escalate.
      nhantenna
      Apprentice
      Blanca_O I am following up on this thread.  This thread is 100 days old without any technical response from Netgear.  At this point we will assume we have a defective Nighthawk.  Can we exchange our Nighthawk at our AT&T brick and mortar store?
