rixIT2
Apr 13, 2025Aspirant
Cant get Managment VLAN to stick on a MS510TXUP
I cant get Managment VLAN to stick on a MS510TXUP.
I try to change the Managment VLAN from default 1 to 9 on System / Managment / IP Configuration. I get the warning screen. Hit okay... and nothing changes. I come back to VLAN ID 1.
VLAN 9 is addes to the VLAN table and I use it perfectly for other products. Netgear products. But not this switches. I have 4 of them, they all behive the same.
Using Management Mode : "Directly Connect to Web Browser Interface"
Software ver. 1.0.5.17
Looks like a newly introduced issue, was fine during the Beta phase. Something to carry forward to Netgear support please and BretD.
-Kurt.
PS. As the MS510TXUP is not a fully Managed Switch, I'll suggest a moderator to move this thread to the more appropriate Plus and Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management models.
- rixIT2Aspirant
I have tried to update to 1.0.5.23 and still have the same issue.
Yea I cant find anything about it..
A my 4 units gives the same problem... changing the Mgnt VLAN ID does not stick.- rixIT2Aspirant
Same problem on firmware v1.1.0.7
Change the Mgmt VLAN ID in the new interface. Still sticky to VLAN ID 1... does not change.
I've tried this and get the same error on the following versions
v1.0.5.17 (3 still of this version.)
v1.0.5.23
v1.1.0.7 (present on one of them)
- rixIT2Aspirant
After extensive research together with the support. This is a bug. Please avoid this product until they fix this issue. You cant change the Managment VLAN ID in a normal way. This is very problemantic. Not even Ciscos switches works this bad... hope they fix this soon.
