dehidding's avatar
dehidding
Follower
Oct 24, 2018
Changing switches in a stack - GS748TPS+GS724TPS -> GS748TPS+GS748TPS
I have a need to change out a switch in a stack made up of a GS748TPS + GS724TPS.  The new configuration would be a GS748TPS + GS748TPS.
Any recommendations on the best way to accomplish this change.  Is it possible to retain the stack configuration through the change?  Should I assume that I'll need to restore the configuration after the change?  Will port 1 of switch 2 retain it's settings, even though the total number of ports will be changing?
Am I correct in assuming that all switches will need to be at the same firmware level?
Here's what I figure the change sequence needs to be:
1. Backup configuration (to local computer along with the stack master)
2. Break the stack - change units to stand alone and reboot
3. Update Firmware on individual stack members
4. Restack the individual units.
5. Restore the backup?
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi dehidding,
    Welcome to the community! :)
    I inquired your concern to the higher tier of NETGEAR Support.  As per the higher tier of NETGEAR Support, the stack configuration cannot be saved in configuration.  The stack likely needs to be broken to add a new switch.
    Yes, make sure that all switches have the same firmware version before doing a stack configuration.
    DaneA
    NETGEAR Community Team
    • DaneA's avatar
      DaneA
      dehidding,
      Just want to follow-up on this.  Let us know if you have further inquiries.
      If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      DaneA
ProSupport for Business
