Gamehendge's avatar
Gamehendge
Factory Reset FS750 48port
I cannot get access to the web gui to perform a factory reset of the switch and the Smartwizard Discovery tool doesnt see the swtich.  The switch has a reset button but that is to just reset to port,etc.  Is there anyway to manually reset this switch to factory or figure out how to access the gui?
  • Hello Gamehendge,
    Welcome to the community!
    Is the the older modular version or the newer FS750T2? The older FS750 does not seem to be supported by the SmartWizard Discovery tool. One way to access the UI is to find the IP address, you should be able to see it on your router's IP table.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello Gamehendge,
    Thanks,
    • Gamehendge's avatar
      Gamehendge
      It is the older version.  Route print gave me what i needed, thanks for the info.
      John
ProSupport for Business
