TWART016
Aug 01, 2016Follower
GS108Tv2 no PoE
Hello,
with the first Port I do not get any power over the port to an access point. With other switches of the series I get the power.
With a PoE injector it works to. Firmware is the newst 5.4.2.22.
Do I have to configure something?
Greetings
Tim
- DaneANETGEAR Employee Retired
Hi TWART016,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
Hi TWART016,
Welcome to the community! :)
The GS108Tv2 is a powered device (PD) and its not a power sourcing equipment (PSE). It can be powered on either by a device that is IEEE 802.3af compliant (PSE) via port 1 or by using the external power adapter that came with it. Since the GS108Tv2 is a powered device (PD), you cannot use it to power on access point via its ethernet ports.
I recommend you the GS110TP switch because it is a power sourcing equipment (PSE) that complies to the IEEE 802.3af standard. It has 8 PoE ethernet ports and you can use this switch to power on up to 8 powered devices such as access points.
For more information about GS108Tv2 and GS110TP, access the links below:
GS108Tv2 and GS110TP Product FAQs
DaneA
