vinyladdict's avatar
vinyladdict
GS316EP - Disable IGMP Snooping on a single port?
Hello - Can I disable IGMP snooping on just a single port on the GS316EP?  I want to leave it on for the rest of the ports.  Thanks!
  • schumaku's avatar
    schumaku
    No way, IGMP snooping can be configured for a single VLAN only, and it's always on all ports.
    Curious what idea you are following to magically address something by disabling the IGMP Snooping functionality just on one port?
    PS. A GS316EP is a Plus switch, and in no way a fully Managed Switch. Requesting a moderator to move the post to the Plus And Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management, accordingly.
    • vinyladdict's avatar
      vinyladdict
      I have 1 of my 14 devices that won’t work on my LAN when Snooping is enabled. I am forced to use WiFi because of this. The tech support representing this device has confirmed their product won’t be recognized unless Snooping is turned off.
      • schumaku's avatar
        schumaku
        Slightly over the head for my old engineering brain. A device or node not able to deal with IGMP won't (or must not!) join a Multicast group, but does it regardless? If it does not join, the heavy Multicast won't hit that port. Do I miss something essential?
        Please tell us a little bit more about the device in question.
ProSupport for Business
