dbecker's avatar
dbecker
GS728TP - Looking for a way to disable 'Validate IGMP IP Header'
ll,
I am looking for an option to disable 'Validate IGMP IP Header' in a Netgear GS728TP Managed switch.  I found a help article which seems to indicate that I should see this option in the web UI of the switch, however it is not present.  I am completely fine with CLI commands to do this if that is the only option.  Anyone know if this is an option or not?
My switches firmware seems to be up to date at version: 6.0.1.18
Help Article in Question:
https://kb.netgear.com/29999/How-do-I-enable-Internet-Group-Management-Protocol-IGMP-querier-using-the-web-interface-on-my-ProSAFE-Smart-Switch
Thanks,
Dale
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi dbecker,
    Welcome to the community!
    You should be seeing the options that is showing on the article as you are using a GS728TP switch. I don't think that we can set it up on CLI as it doesn't have any serial port.
    Please check the manual here(page 108).
  • JohnC_V's avatar
    JohnC_V
    dbecker,
    I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    • dbecker's avatar
      dbecker
      The option was not in the web interface, but I am not sure I was looking at the correct manual when I saw the entry in the first place.  All told I dont believe you can disable this feature in this switch as far as I can tell.
      • JohnC_V's avatar
        JohnC_V
        dbecker,
        This may not be supported on this model. May I know why do you want to disable the 'Validate IGMP IP Header'? What do you want to achieve here?
ProSupport for Business
