BlueFusion
Apr 08, 2017Aspirant
GS7328Sv2 Reboot-loop and I/O Module Issues
Hello, first time poster here.
I have a GSM7328Sv2 with multiple issues. The most pressing is that I have somewhat "bricked" my switch in an effort to figure out why my newly installed AX743 modules aren't working correctly.
I have been running 10.0.0.54 firmware for some months now with no issue. After installing my 2 (used) AX743 modules, I can not get them to work with any SFP+ modules or DACs, including the OEM Netgear AXM761 SFP+ modules. All of the modules I tried work fine in the built-in 10G ports.
With 3 DACs and 1 Netgear AXM761 populating the 4x 10G ports: (note, the AXM761 and DAC in the front were working when this command was issued)
(GSM7328Sv2) #show fiber-ports optical-transceiver all No SFP(s) / Fiberport(s) available (GSM7328Sv2) #show fiber-ports optical-transceiver-info all No SFP(s) / Fiberport(s) available
I had already went into Stacking to disable the rear IO ports stacking and set them up as Ethernet already. Interestly, though, the switch thinks these modules are the 10GBaseT models (AX745): (Note: at this point, there was only the AXM761 module installed, although it still shows as DAC for some reason)
(GSM7328Sv2) #show stack-port
Configured Running
Stack Stack Link Link
Unit Interface Type Product Name Mode Mode Status Speed (Gb/s)
1 0/25 DAC Ethernet Ethernet Link Down 10
1 0/26 Ethernet Ethernet Link Down 10
1 0/27 AX745 (ax745) Ethernet Ethernet Link Down 10
1 0/28 AX745 (ax745) Ethernet Ethernet Link Down 10Thinking maybe it's a firmware issue, I opted to activate the firmware image that was on the switch when I received it, which was an 8.0.x.x version. Upon reboot, the unit became inaccessible and generally resets itself every 1-2 minutes. I removed the I/O modules and this didn't help. I unplugged every cable and this sometimes helps. At this very moment, the switch is running and not self-resetting, however it is inaccessible on any IP address or through any port. I had tried a factory reset with the RST button on the front using various methods (held for 5 seconds while powered on, hold 30 seconds powered on, hold 30 seconds power off, etc.). I can't find any specific way to factory reset the switfch using this button in any manuals.
Does anybody have any advice on what to do next to 1) get the switch accessible and 2) get these I/O modules working correctly?
FYI, I have no serial cable but I just ordered a crossover cable last night from Amazon. It'll be a few days before it arrives though so I'll try anything else in the mean time. I'll also be happy to get instructions for what to do once attached to serial console to get the switch online if nothing else works.
Thanks in advance.
- DaneANETGEAR Employee Retired
Hi BlueFusion,
Welcome to the community! :)
Based from your initial post, it would be best that you open an online case with NETGEAR Support for immediate technical assistance. Kindly state your concern and indicate the troubleshooting steps you did to isolate the problem.
DaneA
NETGEAR Community Team
- BlueFusionAspirant
Good news, my cable came in today and I was able to get the switch booted back into the latest firmware.
Unfortunately, the original issue arises - the AX743 appears as AX745 and no access can be made with connected devices.
That is with a factory reset configuration and then the 27 and 28 ports (rear I/O ports) configured as Ethernet from Stacking.
Also with a factory reset configuration and the above changes, running the original firmware (8.0.3.15), the same AX743 modules appear as AX741 (XFP modules). Atleast in the configuration, the ports work when devices are attached.
There are some glitches and missing options with this older firmware that, while not necessary, I used and would like to have everything up to date and working again.
I'll contact Netgear support, but because I am not the original owner of the switch, I suspect I might not get much help. If this is a real issue, though, maybe they can send out a new firmware.
Has anyone else seen this issue?
As I suspected, the serial number is already registered by a previous owner of the switch....
Here's hoping someone else can confirm this issue with the switch with support and get some fixed firmware.
