JMKIRK
Sep 01, 2017Aspirant
GSM7324 Factory Reset
I have obtained a used GSM7324 for some lab work and need to reset to factory default.
I have followed some guides
power down ... reset button for 10secs.....power on
power down ... reset button for 10secs.....keep pressed power on hold for a further 20 secs.
Neither has worked.
Any advice please
I don't have access to PC/Laptop with serial port so cannot use any console connection.
Thanks for any advice
- HopchenProdigy
Also,
"I don't have access to PC/Laptop with serial port so cannot use any console connection."
Just get an adapter :)
DB9 to USB
- HopchenProdigy
Hi,
Fully managed switches, such as yours, can only be factory reset from:
1. The GUI
or
2. The CLI (via console)
The "Reset" button is just a reboot so it won't do much. If you do not know the IP of the switch, i.e. you cannot get to the GUI - then you need to aquire a console cable.
Cheers
