mervyn28
Oct 10, 2018Aspirant
Look for .opr file for GSM7252PS
Hello
I have a GSM7252PS that will not operate past the Boot menu status.
The power light is amber (versus green)
I connected via the console port to verify the situation.
It appears ...
- Oct 14, 2018
Hi mervyn28,
Welcome to the community! :)
I inquired your concern higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, the .stk file can be use to recover the GSM7252PS switch. There is no need for getting the .opr image.
The latest firmware for the GSM7252PS switch is v10.0.0.53 (.stk file). You can download it on this link.
DaneANETGEAR Community Team
DaneA
Oct 14, 2018NETGEAR Employee Retired
Hi mervyn28,
DaneA
- mervyn28Oct 14, 2018Aspirant
Thank you very much for the help and support, I tried to load the firmware, however, had no success.
I could not use the browser-based solution as the 7252 cannot get past the boot menu and has no IP assigned.
I tried using different TTY clients. I could only get Termite to work. Putty did not.
I tried loading both the firmware and older .opr that I found, via usb neither worked. "Unable to read file" error.
I have concluded that the device is not repairable and no longer usable.
Thank you for your help. I was very much appreciated.
