mervyn28's avatar
mervyn28
Look for .opr file for GSM7252PS
Hello   I have a GSM7252PS that will not operate past the Boot menu status. The power light is amber (versus green) I connected via the console port to verify the situation.   It appears ...
  • DaneA's avatar
    Oct 14, 2018
    Hi mervyn28,
    Welcome to the community! :)
    I inquired your concern higher tier of NETGEAR Support.  As per the higher tier of NETGEAR Support, the .stk file can be use to recover the GSM7252PS switch.  There is no need for getting the .opr image.
    The latest firmware for the GSM7252PS switch is v10.0.0.53 (.stk file).  You can download it on this link.
    DaneA
    NETGEAR Community Team
ProSupport for Business
