stealthrt
Aug 01, 2015Aspirant
Netgear Prosafe GSM7248 Console problems
Hey all this is my first time dealing with a managed switch and i seem to be having issues with trying to log into the RS232 console on it. First thing i did was reset it back to factory defaults (i...
electrotechie
Aug 12, 2015Aspirant
Hi, are you sure that the cable supplied was the original Netgear NULL MODEM cable and not just an rs232 cable?
Google "null modem wiring" and check it with a multimeter against the pics you find there. Failing that, why not just set a pc to offer dhcp service, connect up directly and log in that way?
