ecallenil
Jul 31, 2015Aspirant
Route public IP addresses across switches in internal network
Here's the situation: I have an incoming internet connectoin handing off public IP addresses. This device is on the opposite side of the building and I need to get the connection back to my main...
- Jul 31, 2015
Yes - trunks can handle traffic from multiple VLANs, that is why it's called a trunk you'll need to make it a member of all the VLANs you want it to pass traffic for, and configure it to pass the VLAN tags.
ecallenil
Thanks, fordem, and you are correct. I used terms that are not correct. Instead of "route" I meant something more along the lines of the switches "send" or "pass" traffic. My question is if it is wise, or even possible, to use the already established trunk to pass this traffic? It woud not be desirable from a labor standpoint to run more cable between the switches. Would the trunk be able to pass traffic both on internal and external networks at the same time?
fordem
Jul 31, 2015Mentor
A VLAN is a virtual LAN - think of it this way ...
You have two switches, each with four computers in their own little LAN, each group of four computers can talk to one another, but the computers on one LAN cannot see the computers on the other LAN - these are physically separate LANs.
Now let's take a single switch that supports VLANs and create two VLANs, each with four ports, and connect the computers to them - this configuration will work exactly like the one above, each group of four computers will be able to talk to one another, but the computers on one LAN cannot see the computers on the other LAN - these are virtually separate LANs.
Yes - you can do exactly what you're suggesting because the internal VLAN will never see the external VLAN.
- ecallenilJul 31, 2015Aspirant
Thanks for your reply and sorry for any confusion. I understand what you are saying in that VLANS are separate LANS. What I would like ot know is if the trunk between the two switches can handle 2 VLANS? In other words, I would set up VLAN1 and VLAN2 on each switch, the fiber trunk connects both switches, and I woudl be able to pass traffic from VLAN1 on switch A to VLAN 1 on switch B.
[switch A]-------------------------{fiber trunk}------------------------------[switch B]
VLAN1 VLAN2 VLAN1 VLAN2
