AndrewCole
Mar 26, 2026Follower
Vlan Combine when Partition Walls controlled QSC
Looking for info/ help.
We are using a M4250-26G4F-POE+ with a QSC core to Combine 2/3 meeting room together.
We are using a Huddly Crew Cameras (poe) . I'm looking to Combine 3 Different Vlans together to combine all the cameras
Is there a Easy way or Do I need to use command line prompts to allow / deny vlan controlling?
- BrettDNETGEAR Employee
If the Huddly cameras are using unicast then cross VLAN should work, however with Multicast - they will need to be in the same VLAN as the PC. Theoretically you can use PIM, but I would avoid at all costs. Just put them into one VLAN.
First segregate three cameras into dedicated networks (VLAN) - then bring somehow everything (or at least three cameras) together again. Not sure this is what the original designers intended with that architecture ...
The cameras are designed as a multicamera system connected when connected to a single PC.
So AndrewCole would also need to choose one of the PCs and make sure it is set up to use all the cameras. Using multiple PCs won't work.
Difficult if the individual cameras are - why ever - deployed into different security zones, different VLANs. That's why I'm questioning the initial design.... First add the highest reasonable segregation, then find a way to connect everything together on what I assume to be a single PC, with a single network adapter, connecting to a single VLAN only.
