Itamartaver
Sep 20, 2016Follower
XS708E Jumbo Frames / Firmware-Update issue
Hello!
Please, i have a XS708E and i need to put both switchs (the other one is a Cisco SG500-28) to work together. Wich is the best way to perform this kind of setup? Theres any trick to do this? I'm having a few problems.
If anyone can help me, i'll realy apreciatte.
Thanks in advance.
- JohnRoNETGEAR Employee Retired
Hello Itamartaver,
Welcome to the community!
Are switches in the same room? Wel, you can daisy-chain the two switches. You will have to look at the configuration of both switches, see if you want to pass VLANs on both of the switches. Do you have a diagram or a network plan?
Thanks,
- DaneANETGEAR Employee Retired
Hi Itamartaver,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team- fofwisdomAspirant
I have simlar problem at XS708Ev2
Hi fofwisdom,
Welcome to the community! :)
Kindly answer the questions below:
a. Did you try to perform a factory reset on the XS708Ev2 then check if same problem occurs?
b. How is everything connected? It would be best if you post a screenshot or image (.jpg or .png file) of your detailed network setup.
DaneA
