bgabriels
Mar 11, 2017Initiate
GS105PE - PoE pass through not working until hard reset
I'm facing the same issue as in this topic, but it doesn't seem like there was a solution for this provided before.
I need to unplug all ports, reset the device and then turn it on again.
GS105PE is powered by Fortigate 81E with POE/+ ports.
Fixed by Customer support with Beta Firmware
- jak0lantashMentor
You should contact NETGEAR Support.
- bgabrielsInitiate
- RenegadeTechAspirant
For the record, I'm having the exact same problem as stated in this topic as well as the linked one when powering the GS105PE with an HPE OfficeConnect 1920 PoE+ switch (provides up to 30W per port,) except I can't get my Netgear GS105PE to *ever* show a green PoE light on port 5 or provide power to the PSE ports but for half a second at start-up. Latest firmware loaded (V1.5.0.4) and factory reset performed with no effect.
I'm on hold with tech support now...
- JohnC_VNETGEAR Employee Retired
Hi RenegadeTech,
It seems that this post is too old already. Please create a new thread for this issue.
- Feb 22, 2022Retired_Member
