TigerKR's avatar
TigerKR
Router -> Bridged GS752TP & GS724TP -> LAN & Isolated WAP
Hello, I have a complex setup that I'd like assistance with.
Internet <-> Gateway (Firewall, DNS, DHCP) <-> GS724TP <-|-|-|-> GS752TP <-> WAP
The two switches are bridged (4 ports truncked w/ Cat6). Each switch has many other devices plugged in.
I'd like the WAP (wireless access point) to be isolated from all of the other LAN traffic (on both switches), but be able to access the internet via the gateway. Can I do this without an additional (hardware) firewall between the switch and the WAP (blocking all other non gateway, local traffic)? I'd like to avoid a double NAT stuation if possible.
Would I be able to setup a VLAN for a single port on each switch to accomplish this goal?
WAP <-> VLAN Port on Switch52 <-> VLAN Port on Switch24 <-> Gateway <-> Internet
I guess in this case I'd run a 5th Cat6 cable between the switches (separate from - but in addition to - the 4 trunked ports).
Would this work?
Thank you!
  • Then you're set. Just plumb the VLAN all the way through both switches to the gateway.
  • You don't need to run a 5th cable. You can provision a new VLAN to run across the existing trunk.
    The bigger question has to do with the gateway. Does it support VLANs?
ProSupport for Business
