CloudLostItAll's avatar
Aug 29, 2015
Prosafe FVS114 Dynamic DNS provider page displayed as blank
Before updating the firmware from v1.1_11 I thought that I had the DDNS page available.
After updating the firmware to v1.1_15 the page does not show up. It comes up blank.
Is this a problem with the firmware update?
does the original v1.1_11 have the same problem? (not showing the page)
can I return to the previous firmware version?
Thanks in advance for any constructive info on this subject.
  • So this leads me to a followup question:
    What piece of equipment that Netgear manufactures/produces that has an interface to www.no-ip.com web site?
    I read the following concerning the  FVS336Gv2 :
    That FVS336Gv2 has no Dynamic DNS support which calls from the DDNS page  ==>  http://www.no-IP.com.
    It does support the following though:
    Dynamic DNS,
    DNS TZO,
    DNS Oray, &
    3322 DDNS
     As I have written in the previous post that the FVS114 does not support/point to http://no-ip.com, so the question is, is there a  piece of equipment that Netgear manufactures/produces that has an interface to http://www.no-ip.com web site?
    There was a previous post on this thread which points to a Netgear page that indicates that the FVS318Gv2 is the replacement for the ProSafe VPN Firewall FVS114.
    Does the FVS318Gv2 or FVS318n equipment DDNS page have a pointer to http://www.no-ip.com?
    • SamirD's avatar
      SamirD
      Prodigy
      Looking at the dynamic dns section on my FVS318N, I can say no, this unit does not support no-ip (at least on the firmware I'm on).
      I just read about a TP-Link r600vpn that seems like it might.  Check it out and see.  I know where to get these under $50 brand new, so if can do what you want, PM me and I'll send you the link.
  • The following is the page from the ProSafe VPN Firewall FVS114
    Dynamic DNS
    Use a dynamic DNS service
    -  None
    -  DynDNS.org       Click here for information
    -  TZO.com            Click here for free trial
    -  ngDDNS             Click here to register
                                  Apply           Cancel            Show Status
    When you click on any of the three options you are pointed to the following address
    -  DynDNS.org       Points to  ===>>  http://www.dyndns.org/     (Which is resolved to)  ===>> http://dyn.com/dns/
    -  TZO.com            Points to  ===>>  http://dyn.com/
    -  ngDDNS             Points to  ===>>  http://ngddns.iego.net/   <<===  this page no longer is resolved to a web site.
    The first two option point to basically the same place
    ===>> why is there not a pointer to www.no-ip.com <<===
    CloudLostItAll
  • Glad you fixed it! I have a lot of legacy (aka old, obsolete, etc) computer and nwtworking equipment so ive run into this type of thing before. Now that i am thinking about it, i think i know why the 100Mbit uplink ports on an old 10Mbit switch didnt test at 100Mbit the last time i tested them--because the switch was built before the nway auto-speed negotiation standard! I'll have to try the test again. I didnt think those switches had gone bad--they were $900 new back in the day.
  • Hello All,
    Ok I took the suggestion that it might be the browser that is causing this problem.  For v.38 & 41.0 FireFox does not display the DynDNS page.
    So I downloaded Google's Chrome Version 45.0.2454.99 m & the DynDNS page is displayed.
    Problem solved........
    Thanks to all for your help & suggestions.
    P.S. The FVS114 is running the v1.1_15
    Cloud LostItall
  • I have loaded the following Firmware Ver. onto the FVS114 router:
    1.1_01
    1.1_06
    1.1_10
    1.1_15
    After each loading of the different firmware versions I reset the router to factory setting  & nothing shows up on the Dynamic DNS page.
    It comes up blank (color gray) with no text showing.
    P.S. so something has changed in the router & I am not sure what it is at this point, since I had the page before uploading the 1.1_15 ver. of the firmware.
    CloudLostitall
    • SamirD's avatar
      SamirD
      Prodigy
      If you have tried reverting the firmware, then I have to believe it is in the browser that you're using.  Try a completely different computer with a completely different browser.  Also, one that may be older may be best since the firmware is also dated.  (I will usually use a linux live cd for this type of testing--easiest way since you can use the same physical machine.)
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi CloudLostItAll,
    A few questions below:
    a. After updating the firmware to v1.1_15, did you perform a factory reset?  If not, it is recommended to perform a factory reset after updating the firmware then reconfigure it from scratch.
    b. Have at least tried using other browsers to access the web-GUI of the FVS114 and check if the Dynamic DNS page is still blank?
    I look forward to your response.  Welcome to the community! :smileyhappy:
    DaneA
    Netgear Community Team
    • 1. After updating the firmware to v1.1_15, did you perform a factory reset?
      I did not, but will.
      2. If not, it is recommended to perform a factory reset after updating the firmware then reconfigure it from scratch.
      I will & return to write what happens.
      P.S. I am going to hate to do this. Is there a way to copy the current configuration to a file?
      3. Have at least tried using other browsers to access the web-GUI of the FVS114 and check if the Dynamic DNS page is still blank?
      I have tried both FF & Chrome with no results (blank page)
      Cloud Lostitall
      • DaneA's avatar
        DaneA
        Hi CloudLostItAll,
        Performing a factory reset right after updating the device to its latest firmware version gives you a clean setup using the latest firmware version.  Furthermore, some enhancements as well as bug fixes of the latest firmware version cannot be obtained without a factory reset.
        Kindly observe if same problem occurs after doing a factory reset.
        DaneA
    • SamirD's avatar
      SamirD
      Prodigy
      Ditto on these suggestions.   Very curious what you come up with.
ProSupport for Business
