W4NMH
Feb 14, 2021Aspirant
WAC 510 Multiple SSID lost during scheduled reboots but OK on "Cold Starts"
WAC 510 with Multiple SSID works great, until a Scheduled Reboot occurs. -Only SSID's created prior to the last two Firmware Updates become Visible on Client Devices. A "Cold Start" (Remove and ...
- Mar 05, 2021
This can be "Marked" as Resolved
1. Not all clients are dual band cable nor all clients 20/40/80 MHZ Capable.
2. Not all clients are N/AN/AC Capable.
I have seperate SSIDs to accomodate different parameters, i.e. Band Steering.
I have created a "2G" Only SSID for this purpose.
I learned that my SSID Monitor, iPhone S6, does not do well with Bandsteering 2G to 5G at 80 MHZ, now using 40 MHZ.
I am also in a "High Density" Urban Enviroment so as not to overlap there are only three non-overlapping 20 MHZ 2G Channels, 1, 3, and 6. -Interference Mitigation.
Set Parameters to 2G 20 MHZ, 5G 40 MHZ to accomodate older Clients.
SSID "2G Only" has Bandsteering Disabled, to accomodate older Clients.
Note: Even on another brand of AP 2G Only a HP 6700 Printer that is only 802.11 b/g capable did not re-aquire on loss of WiFi during re-boot. The Printer required rebooting.
So in some Client instances scheduling the Client Reboot after the AP Reboot maybe necessary, as well as Disabling Band Steering for older Client Devices.
Rich W4NMH
W4NMH-2
Mar 03, 2021Aspirant
I tried to reproduce the issue with my configuration. And learned a few things I would like to share.
We set our Parameters to 2G 20 MHZ, 5G 40 MHZ.
One SSID "2G Only" has Disabled Bandsteering.
I think this has resolved the issue, atleast testing with Manual "Warm Boots."
-Scheduled Reboots will be tested next.
Rich W4NMH
W4NMH-2
Mar 05, 2021Aspirant
Rich W4NMH
