JDF7's avatar
JDF7
Tutor
Jul 17, 2024
Factory Reset fail
Hi Orbi Community,
I factory reset my router try to get rid of my old SSID but after two resets I still see them being broadcasted in my known networks. (still connectable) I used to video tutorial provided on Orbi’s Support website but to no avail, they are still there.
    • schumaku's avatar
      schumaku
      In case your ORBI SXR80 is enabled for using Netgear Insight it will (in my understanding) fetch the config again even after a factory reset. You might have to go the Insight App or Insight Web portal for configuring and changing the SSID as per your new requirements.
      Not sure fellow FURRYe38 has spotted there are (for reasons) no Orbi Pro systems listed on the KB article referenced. Feels like a lack of any practical experience operating Orbi Pro or any other Netgear Insight managed devices.
      FMI: How do I reset an Insight Managed Switch or Wireless Access Point to factory default settings in Insight?  The same applies to all Netgear Insight managed devices, including the Orbi Pro systems.
    • JDF7's avatar
      JDF7
      Tutor
      I have the Orbi Pro Wifi 6 SXR80 router and satellite. I can't login into the web control page right now so I used the hardware reset.
  • plemans's avatar
    did you factory reset and/or re-sync the satellites?
    I've noticed that if I only reset the router and don't sync the satellites, the satellites will retain the same ssid until that has been done
    • JDF7's avatar
      JDF7
      Tutor
      Yes i have tried re-syncing the satellite but it fails (doesn't show in the Orbi Insight app)
      • FURRYe38's avatar
        Did you reset both SXR and SXS?
        If you ethernet connect the SXS to the back of the SXR, does the SXS get an IP address from the SXR?
  • FURRYe38's avatar
    One can find the ERASE button on most if not all NH routers, home and business:
    JDF7 wrote:
    Hi Orbi Community,
    • schumaku's avatar
      schumaku
      SXS80 are pure satellites, and cant be operated without a router resp.  main unit like  SXR80. This is the unit controlling everything.
      • FURRYe38's avatar
        The ERASE button sends a FR to all SXS and the SXR.
ProSupport for Business
