mt_shawna
Aug 06, 2025Aspirant
External IP Address is a private IP
Hello,
How do I find the public IP address for my router? The IP in the Nighthawk app for External IP Address is a private IP and not a public IP. Because of this, it is breaking my tv streaming IP as it is a private IP address and they require my location through a public IP. I cannot find how to change this to a public IP or where I can get a public IP. And I cannot contact support as my router is 2 years old.
mt_shawna wrote:
but I am now able to access Sling TV on all devices
Great!
mt_shawna wrote:
I am not sure what changed - maybe that router reboot I did again yesterday just took some time to set everything back to normal?
0r maybe something changed at Sling's end (or perhaps some other problem with the infrastructure between you and their servers).
- mt_shawnaAspirant
Great point, you could be spot on there. Thanks again!
- mt_shawnaAspirant
Really appreciate everyone's help on this. I am not sure what happened but I am now able to access Sling TV on all devices. Checked the IPs in the Nighthawk app and nothing changed. I didn't change any other settings (I do not have parental control set anywhere). I am not sure what changed - maybe that router reboot I did again yesterday just took some time to set everything back to normal? I don't know, this is a mystery to me! Thanks again for everyone's help on this!
100.80.1.109 is not a "private IP address":
https://en.wikipedia.org/wiki/Private_network
I do not seem able to find out much about this IP address:
The address is in the 100.64.0.0/10 block. Technically not "private", but not "public" either. Instead it is "shared" within each ISP. See https://en.wikipedia.org/wiki/IPv4_shared_address_space
The address block is specfically reserved for CGNAT (as your bottom screenshot suggests). It was carved out in 2012, when the IETF adopted RFC6598. This was one of several measures taken in that timeframe to manage IPv4 address exhaustion.
Like private addresses, these are not internet routable, because all ISPs deploying CGNAT are re-using the same addresses. This is analogous to private addresses being re-used by all home routers. They are of course routable within each ISP, just like private addresses are routable within your home network.
- mt_shawnaAspirant
Thanks for the reply. The Nighthawk app is showing 192.168.1.1 as the IP Address (internal) and the External IP Address is 100.80.1.109 (This is the private IP my ISP confirmed is correct). I have tried rebooting the router and I have also unplugged the modem for a couple of minutes, two times. Nothing changes on the IP addresses.
Sling indicated that they are seeing my IP address as 0.0.0.0. I cannot see where they are seeing this, that is what they told me. I am not sure if it is in my Sling account as I cannot log into when using the router due to Sling seeing my IP address as 0.0.0.0. I may try to log in later when I can connect directly to the modem with wireless disabled.
FWIW, that is in the address space reserved for carrier-grade NAT.
But if the problem was caused by CGNAT, then it should also fail when you are directly connected to the modem.
Might be worth confirming that you can access Sling on your phone with the phone connected to mobile data (not wifi). I suspect that will work.
Another test is to temporarily put your laptop in the DMZ of your router, and see if that works. That would let us know if the NAT firewall in the router is somehow getting in the way.
Do you have parental controls enabled in the router?
- mt_shawnaAspirant
Hi, thanks for the replies! I have a Netgear R6260 router that is connected to a DZS modem . I talked to my ISP (Global Net) and the IP in the External IP Address on the NightHawk app is correct. That is the private IP address that is part of the cgnet I am on. That traffic does route to their public IP address for the internet. They have not made any changes to their IPs.
Sling TV is thinking I am on a VPN as they are showing my IP address as 0.0.0.0. This started last Thursday, July 31st. I plugged my laptop directly into my modem, disabled wireless and I can successfully access Sling when the router is not a part of the connection. As soon as I switch back to wireless and connect to the router instead of the modem, Sling is no longer accessible. Sling is broken on Firestick TV, Apple iPhone and iPad as well as my Dell laptop. I checked sling on my parents wireless when I was a their house and can successfully access it. I've had Sling for several years and never had an issue. Was there a Netgear update last Thursday that changed something with my IP address?
The IP address for Netgear, 192.168.1.1 is marked as private on IP address websites. I am guessing Sling may be pulling this IP address from my router and hence thinking I am on a VPN? Thanks for any answers!
If that is a private address then they must be using CGNAT.
Is 192.168.1.1 the external address you are seeing for the router? Or is it the internal address?
Then the CGNAT must not be the problem. If it were, then it would also fail when connected to the modem.
Where are you seeing this info?
I don't have your router. The current firmware (version 1.1.1.88) is timestamped 2025-01-21 (so not that recent).
Did you try simply rebooting the router?
Either you are double-routing (connecting your WAN port to a gateway, and not a modem), or your internet service provider is using Carrier-Grade NAT (CGNAT) or equivalent.
- Can you provide the manufacturer/model of the device your router's WAN port is connected to?
- Who is your ISP?
Lots of information without much for us to work with.
What router do you have?
What modem/gateway is it connected to?
Who's your ISP?
What streaming service and app/device are you using?
Who's telling you its a private vs public IP address issue? And why?
Please identify the model number of this router and the Internet Service Provider (ISP) equipment that it is connected to.
If the WAN IP address is a 'private' IP address, then the router is not connected directly to the ISP network. For example, the ISP may have installed a WiFi router (which has the public IP address) and your router is connected to it.
There are many web sites that will report the public IP address, such as https://whatismyipaddress.com
