utschy's avatar
utschy
Initiate
Nov 15, 2015
Netgear Genie will not work on my new Windows 10 machine. Closes immedieately
Hi, Just got a new HP Spectre 360.  It installs and just as it is opening, a dialog box "Netgear Genie has stopped working. Aproblems caused the program to stop working correctly.  I uninstalled the program and reinstalled it.
Same problem.  I just installed it on my windows 7 machine.  No problem.  Is this a compatability issues.  I do have Mcafee virus scan. I have no idea if this is the problem or how I would change it to give permission to run Genie.
Any help is greatly appreciated.
 I also tried to close and restart the computer. That didn't help.
Adrian
  • PS,
    I just downloaded the program today from the netgear website that was listed as the "solution" to the problem.  This must be the latest version of this program.
    • owl1000's avatar
      owl1000
      I have a similar issue not update provided for windows 10 a pathetic response. There  should have been an immediate update provided for a major product release like Windows. Next time I will be more careful to buy a product with decent support
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi owl1000,
        We are looking into this situation since not all Windows 10 devices are affected. Considering that Windows 10 is a fairly new release, there are plenty of under the hood updates that are continuously being pushed out that may not play well with some programs. Installing the previous of NETGEAR Genie is a temporary work around for now. If you have not installed it yet, you can use the download link below.
        http://files.netgear-support.com/go/?a=d&i=i82p82s4Oy
        Dexter
        Community Team
  • The genie does not work on my HP spectre X360, not even support could get it to work, what gives?
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi @Fastercat,
      If your computer is using Windows 10 and is getting an error message, you may follow the steps below.
      1. Uninstall the NETGEAR Genie program from the computer/device.
      2. Download the previous version (2.4.12) of the NETGEAR Genie.
      Download link:
      https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92eE81a20xRjg/view?usp=sharing
      3. Install the program and check if it functions correctly.
      4. Locate the drivers folder under C:\Program Files\NETGEAR Genie\bin and copy it to the desktop.
      5. Download and install the latest version of NETGEAR Genie again using the download link below.
      http://netgear.com/home/discover/apps/genie/aspx
      6. Look for the same folder under the same location and delete the folder.
      7. Replace the folder with the folder that you pasted on the desktop from the working version of NETGEAR Genie.
      8. Close the NETGEAR Genie program through the system tray.
      9. Re-open the NETGEAR Genie program and check if it works.
      Dexter
      Community Team
      • Fastercat's avatar
        Fastercat
        That link doesnt work, it says not responding, need to close progam, and yes i am running windows 10 on my hp spectre i7
  • Upgraded from Windows 8.1 and the Genie continues to work just fine.  Now on the Windows 10 Preview version, nothing from Netgear works.  None of the adapter software genies.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi @VietVetF4Drvr,
      1. Have you tried uninstalling and re-installing the drivers for the adapter?
      2. Device drivers are tested to work on stable/public builds and not on preview/insider builds.
      Dexter
      Community Team
