I_Must_Know's avatar
I_Must_Know
Follower
Aug 28, 2026
Netgear Mobile App blocked notifications
Hello everyone.
I've been unable to find a solution to this issue.
It's weird enough that Android has this app under System apps.
But the OS will not allow notifications from the Mobile App "All notifications from this app are blocked".
When I go to App notification and switch the enable button, the OS disables it again.
The android os is version 13.
Has anyone here found a solution?
Thank you.
1 Reply
  • Hope someone comments on the Nighthawk app.  I have the Netgear Orbi app installed on Android 16 and it definitely allows notifications:
    It might be helpful to find someone with a more recent Android version and temporarily install the Nighthawk app on that device.
