3791eidde
Dec 17, 2019Tutor
DumaOS not loaded yet!
For some reason my router login password stopped working. I had to reset the password and when I logged in I get this message.
Any idea whats going on?
- I did a reset, I get the same issue when I try to login. I had this router running for about a year with no issues. All the sudden today I got this issue. - Netduma-FraserNetDuma PartnerDoes this occur for the entire interface i.e. you can't access any page or is it on specific pages it happens? In System Information on the R-App panel options change the number of retries to 5 instead of 3 and then reboot the router please and see if that helps. What is your firmware version?- This happens after login. I am unable to go to any pages. I am on the latest firmware. Did a factory reset and there was no updates.
- Dr_Evil_GeniusInitiateI'm reporting the same issue. Both myself and my friend living across the country logged onto PSN and got the same exact problem. We used this workaround: 1. http://routerlogin.net/adv_index.htm 2.Administration -> Firmware Update 3. http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip 4. Unpack the .zip file 5. Browse to Image file 6. Upload This got our XR500s working for now. I hope this helps and I hope this issue gets a permanent solution soon. - Thank you for that. - Netduma-FraserNetDuma PartnerThank you Dr_Evil_Genius for that workaround. It seems a few people have experienced this today, I have raised this with our team so we will investigate this ASAP. If you're having issues please follow that workaround.
- HilockInitiate
 Dr_Evil_Genius wrote:I'm reporting the same issue. Both myself and my friend living across the country logged onto PSN and got the same exact problem. We used this workaround: 1. http://routerlogin.net/adv_index.htm 2.Administration -> Firmware Update 3. http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip 4. Unpack the .zip file 5. Browse to Image file 6. Upload This got our XR500s working for now. I hope this helps and I hope this issue gets a permanent solution soon. Thanks, the problem was solved. I stop the auto update to keep this Firmware
- lr18lrInitiateSame issue here. Firmware updated two days ago after purchase. Ran fine until this afternoon and now I cant login. There were no changes between working and non working.
- ViperGodInitiatewhen using http://httprouterlogin.net/adv index.htm
 my browser or my XR500 was locked to the DumaOS. I had go
 old school typed in its IP address.
 So if anyone else has that problem just type or copy and pasteor http://192.168.1.1/adv_index.htm Thank you to Dr_Evil_Genius for thinking of a workaround. - ViperGodInitiatehttp://routerlogin.net/adv index.htm (correct) sorry, I was typing either to fast or thinking to fast.. - Netduma-FraserNetDuma PartnerThanks ViperGod, I will update my main posts with this information.
- Adem-K28AspirantI’m having the same issue- Netduma-FraserNetDuma PartnerPlease take a look here for the latest information on this issue: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Please-read-if-you-re-experiencing-DumaOS-not-loading-login/td-p/1838062/jump-to/first-unread-message- Netduma-FraserNetDuma PartnerWe have now fixed the issue, please see here for the fix: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Fix-for-quot-DumaOS-not-loaded-yet-quot-XR500-users-only/m-p/1838160#M15459
- SlurpsInitiateSame issue here. Been scratching my head all day about this, but I'm about to downgrade the firmware myself to resolve the issue as it seems this is a fix according thos this forumn and a few others I checked out. - Netduma_JackNetDuma PartnerHi - it should now be fixed actually, so instead of downgrading could you try rebooting your router instead (i.e. turn it off and then back on again). Please let us know if that fixes your problem
- Netduma-FraserNetDuma PartnerPlease see the fix I posted above, it should just require you to do a reboot if you're on the current .56 firmware.
- SlurpsInitiateSorry didn't read the post above me. Restarting router now to try and see if it's all fixed before I downgrade - BonkeydaveAspirantI have returned from a business trip to this issue, reboot of router does not fix the issue
- dan801ApprenticeSame issue here since yesterday. Mulitple re-starts same issue. Last option is Reset which I'm not keen on. - burTutorHi Dan801 try : 1. http://routerlogin.net/adv_index.htm 2.Administration -> Firmware Update 3.Router Auto Firmware Update -> I Disagree
- Netduma-FraserNetDuma Partnerdan801 you most likely just need to delete the cache/cookies on your web browser and then you will be able to access the interface.
