Oregeki
Jun 15, 2020Follower
C6300v2 2.4ghz not connecting
OK so on 6/14/20 our Iphone's, ps4, old windows 7 laptop, nintendo switch, etc any devices that werent directly connected to the router stopped showing the 2.4 ghz connection. It had been showing for part of the day until our internet connection went out for a few minutes and i had to reset it.The 5g connection is stil showing and ive contacted my service provider and they confimred the signal was working.
A Few points here:
- Yes ive reset it several times,
- The lights for 2.4ghz on the front of the router show green as does every other light
- I did not change any settings or log into my router at all for the past 3 months since i installed it, until today
- Yes it shows as active in the router gateway and turning it off and back on again did nothing.
I am no computer expert so any advice or ideas i would greatly appreciate it.
Thank you!
Power dying can cause power surges. Which play havoc with electronics. It might have caused it to fail.
You've tried a lot of the key points
the only other things I'd try would be:
1. turn the wifi on/off using the wifi on/off hardwired button. push and hold it for 2 seconds
2. Try a different power supply. maybe the power supply is going bad. If you have a power supply with the same voltage and polarity (it can have higher amsp but not lower) you can try it. I wouldn't buy one.
Is it still within warranty?
You can check it by going to mynetgear at the top, register an account and then the device. If its still within warranty, you can start the rma process from there.
- SFieldsAspirant
Did you ever figure this out?
I am having the same issue. The 5G connection is showing but not the 2.4. I have done on the sets that you show you did also. Still nothing. I have some devices that do not connect to 5G so I need the 2.4.
Thank you for any reply.
- wcalifasProdigy
You can also try updating the firmware or reloading it and see if it revives the 2.4gzh band.
> revives the 2.4gzh band.How, exactly, do you propose that the user should do that with a
DOCSIS modem+router?
- olympos1625NETGEAR Employee Retired
Hi Oregeki and SFields,
Good day! Thank you for reaching out. First of all, we do apologize for the inconvenience this has caused you. Have you tried contacting our Support team? This could be a hardware issue and our SUpport team will be one to do a hardware check. If it's within the hardware warranty, we will be able to replace the Cable Gateway.
If you have any other questions, please do not hesitate to ask.
NETGEAR Team
- SFieldsAspirant
Hi,
Yes we did reach out to Netgear, my modem stopped working completely no wifi 2.4 or 5.
We were on hold for 55 mins and had to hang up because at 8:45 we had to make the decision to go buy a new modem before the store closed. I had to work from home and 2 kids doing school from home the next day.
We are now up and running on the new modem but it's only 2.4 no 5 this time. I'm beyond frustrated. I'm on the phone with Xfinity currently. Then i guess I will call Netgear next.
- tobrahaAspirant
Same exact issue here; tried everything short of a factory reset, which I'll probably try later this evening.
I called support to plead for a hardware warranty replacement, but was told that the hardware checks all passed and that the network was "overloaded" and thus the 2.4GHz network was deactivated. I've been using this modem for almost a year with no changes to the network or number of devices. Support case # 44030062.
If I make any progress with a factory reset, I'll reply here, but not looking hopeful at this point :(
- tobrahaAspirant
Thanks, plemans. I suppose a scam wasn't outside the realm of possibility, but it seemed legitimate...
That's exactly what I was thinking, but I didn't want to hammer the poor girl from Netgear support too hard.
The only device that doesn't support 5GHz is the smart TV (which is surprising; it's a Samsung 55" that's only ~3 years old).
I'll give the factory reset a whirl and will post an update when I get around to it.
Thanks!
-Tommy
- tobrahaAspirant
UPDATE: Issue resolved.
I was able to resolve my issue by completing a FACTORY RESET of my C6300v2. Really glad I didn't pay for a support contract on this...
