Ploeggie's avatar
Ploeggie
XAVB 5601 does not work
Hi,
Recenty purchased two used XAVB5601/AV500 powerline. Seller says they work.
All lights are burning, No problems from the outside.
However...cannot get them to work.. reset them several times, set security, tried without security, connected them from router to PC and nothing, to PS4 also nothingh.
Any ideas about what is wrong ?
Also got a set of XAVB5602 and they work 100% in a simular setup, also tried to add one of the XAVB5601 into their network... but  no result..
Any suggestions ?
Thx,
Sander
    • Ploeggie's avatar
      Ploeggie
      Hi,
      Thx for yr help.
      Downloaded the software, did the reset.
      got three green lights now, but my PC keeps saying 'no internet' on this connection.
      Any other suggestions ?
      thx
      Sander
      • clithes's avatar
        clithes
        Prodigy
        When you run the powerline utility does it find all the adapters ?
        For any that it doesn't, connect these to the PC and try to reset again
  • OK try connecting each one of these to your pc and resetting the encryption key to HomeplugAV as well
    • Ploeggie's avatar
      Ploeggie
      connected all 4 plugs and did the reset same way on the them..
      still no internet/ nothingh
      connected the XAVB5602 only and they work, Cannot get these XAVB5601 do to the same, are they broken ?
      • clithes's avatar
        clithes
        Prodigy
        When you connect the XAVB5601 units to your PC and run the utility, when you try to factory reset them does it say that they have been reset, or 'Factory Reset failed' ?
  • Adapter connected to router is connected via an extension cord. Tried also an other socket without extension cord but No succes
    • Ploeggie's avatar
      Ploeggie
      just bought 2x new TP-link powerlines.
      Worked immediately, connection fast toghether with the XAVB5602 from netgear.....
      anyone wants two defective netgears 5601's ?
      • clithes's avatar
        clithes
        Prodigy
        Must have been faulty then.  Sorry we couldn't solve it
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi Ploeggie,
      clithes might be correct that the device is faulty. You have tried reset on the device but still no connection but it works with to another powerline adapter. You may try to connect it in just one room where the router is. If still the same then possibly the adapter is faulty.
