funkygecko
Nov 14, 2016Aspirant
Can't connect to ReadyCLoud, but connects to Raidar...
Ive had my ReadyNAS 102 for a few years and its worked fine. I have it setup to link directly through ethernet from Rn102 to my iMac. I have the unit setup with Time Machine for my backups, and a month and half ago it said it had to do a new reboot of the unit and start a fresh Time Machine backup. As an aside, i have the new OS Sierra on my iMac.
Long story short, the Time Machine can't make a new backup, so i thought i'll log into the ReadyCloud and wipe it and start with fresh drives. However now my computer doesn't see the RN102 through readycloud. The odd thing is is that RAIDAR can see the unit, but readycloud can't find/discover it.
I'm thinking maybe the OS Sierra update did somethign wonky....honestly any recommendations are welcome. Thanks!
You can start over w/o using readycloud. Can you access the web UI directly?
- funkygeckoAspirant
Not sure how to do that...
https://nas-ip-address/admin
You should be able to see the NAS iip address from your router.
