Retired_Member's avatar
Retired_Member
Jul 05, 2017
Re: ReadyNAS 204 - MyCloud and ReadyCloud aren't working.
Well, I just uninstalled MyCloud and installed ReadyNasRemote again and today it worked... the last 20 times it did not. Tried both back and forth. However..... now there is an error when I try to login to my ReadyCloud account online. It logs in okay and displays the first page but then we get an error with a big red X that says:  6001010106
  • Retired_Member's avatar
    Retired_Member
    Jul 11, 2017
    Well, I am sorry you did not come up with a solution for this but I am glad to say that I have now gotten it working.
    I logged into my ReadyNAS RN102 at home using TeamViewer and connected locally to the Netgear Raid.
    I then removed my ReadyCloud account from the Ready NAS Cloud tab and then rebooted the drive.
    I then added the same identical account back in to the Cloud tab, rebooted again and now I am able to connect remotely to the online ReadyCloud.
    Cheers!
  • StephenB's avatar
    Retired_Member - did you post this on the wrong thread?
    If so, let me know if you want me to move it.
      Retired_Member
       If you feel it is in the wrong place, please go ahead and move it but I don't believe so. This problem was apparent in both MyCloud App and NetgearNas Remote.
      • StephenB's avatar
        This thread is about Windows 10 SMB backup jobs failing.  I will split your's off into it's own thread.
ProSupport for Business
