shaunleblanc
Oct 22, 2017Aspirant
ReadyNas 102 w/ Firmware 6.8.1 + ReadyCloud V2.0.0 on iOS 11 - Media Backup Not Working
Since updating to the above details the media backup won't work. It will sit in a state of uploading and never make it past the first picture. Everything worked fine before. Is there an issue with Firmware 6.8.1 or the V2 of the iOS app?
- Shaun
- shaunleblancAspirant
Hello? Moderators/Support care to respond? Anyone with similar issues?
- Anonymous
Hi shaunleblanc,
Have you tried uninstalling and re-installing the iOS app and check if you will still have the same issue?
Welcome to the community!
JohnM_S
NETGEAR Community Team- shaunleblancAspirant
Hi John,
I did delete and re-install twice and still no luck. I'm seeing others who are on iOS 11 are posting similar issues so I'm wondering if the ReadyCloud app doesn't play well with iOS 11.
- Shaun
