jokeruk
Apr 01, 2024Aspirant
ReadyNas keeps 'losing' password
Hi folks, one of my ReadyNas Ultra 6 devices keeps losing its password - admin and others.
Losing might not be the right word but symptoms are can no log in to the web interface using admin or any account.
Shares continue to work as do scheduled backups.
The only fix is an OS reinstall which obviously resets the password to default.
I've even (as a test) tried leaving it on the default password and after a random period of time (1 week/1 month..) log in access to the UI will be lost.
I can still telnet in to root using the admin password in all cases.
I'm running OS 6 (on both NAS boxes) with all latest official updates but this only happens on one of them.
I took the rash step of a complete factory wipe and rebuild but that has not stopped the problem occurring.
Just a thought as I type this question - could this be a battery issue?
Regards
Steve
No.
Do you mean ssh? Telnet connections are refused unless the NAS is in tech support mode - and that uses a different password.
If you can use ssh, then see if it also works using admin as the user name.
The symptoms sound more like a PC issue than the NAS.
Have you tried
- connecting both using the NAS hostname and its IP address?
- a different browser?
- using incognito mode?
- a different PC?
- rebooting the NAS from the front panel?
- jokerukAspirant
Ah yes sorry, SSH,
using admin and admin password does not work via gui but ‘root’ ad admin password works via SSH
- jokerukAspirant
Once the problem occurs nothing will help until an o/s reinstall.
after that I can log in as usual from any pc or ipad using factory log on details.
we have a mix of o/s and browsers - just tried this morning with a windows xp machine (used for legacy software for vehicle programming)
We’ve tried: Edge, Safari, Chrome, Firefox over windows xp, 10,11 - don’t have a win7 build at the mo although could spin up vm
