everytime
Jan 29, 2016Guide
Suddenly unable to get to NAS via ReadyCLOUD
For the past week or ten days, I've been unable to connect to my NAS via ReadyCLOUD. Previously I have had no problems.
So, I thought I'd reboot the server and do some dust removel while it was off-line. It came back up fine, but the problem still exists.
When I connect locally to the server (using a local IP address) I have no problem, but from, say, Starbucks or my local library I'm unable to connect. I can log in fine, but I'm never presented with the server. I just get a gear spinning.
I thought I'd try to shut down ReadyCLOUD, but that's taken me into a logical loop: I've tried to remove the one user, but I'm told that in order to remove the user I need to log in to ReadyCLOUD. However, I can't log in to ReadyCLOUD so I can't remove the user.
Can someone suggest how I can get ReadyCLOUD working again?
I'm in an all Mac environment if that's of any use. Thank you in advance for any help you can offer.
- JennCNETGEAR Employee Retired
Hello everytime,
Are you using ReadyCloud app? Please check if same problem that you cannot see your NAS when login at http://readycloud.netgear.com.
You can also try disabling ReadyCloud from the admin page then enable it again. See if the Internet and Services also have green check marks.
JennC, thank you for the response. I'm a little more confused about ReadyCloud now, though.
Since getting the ReadyNAS 516 about a year ago, I've always used a browser from my MacBookPro when not on my local network to use ReadyCloud. Is there an app for the Mac OS? If so where can I get that? I looked for the app. When I go to the Netgear Support Download Center, however, and enter "ReadyCloud" in the box "Enter a Product Name/Model Number" it returns "No matching results." Is there somewhere else I need to go to download the ReadyCloud app?
So as I said, I always used a browser to get into ReadyCloud. But now after I log in to ReadyCloud I get a screen that says "Currently you have no registered or shared devices / Go to Discover page to register your ReadyNAS device, or if you have a router with ReadyCloud support, browse http://routerlogin.net. go to ADVANCED > USB Functions > ReadySHARE Storage > ReadyCLOUD tab to register your router." (I tried to attach an image of that screen, but the pop-up window to attach an image doesn't permit me to browse my computer so I didn't know how to attach it.) I'm also uncertain about what ReadySHARE Storage and/or USB Functions have to do with the ReadyNAS connected via Ethernet to my local network.
Anyway when I click on "http://routerlogin.net" a get the message "Server not found."Again, thank you for your assistance.
Hello everytime,
Yes there is, a BETA version though, https://readycloud.netgear.com/client/install/ReadyCLOUD.pkg is the link. A lot of users already use this.
Anyway when I click on "http://routerlogin.net" a get the message "Server not found."Ignore the steps you have seen that is actually referring to a NETGEAR router that has ReadyCloud feature too and the USB port. routerlogin.net is also a link for NETGEAR consumer routers that have ReadyCloud.
So, have you tried the last suggestion I gave on my previous response?
- wlcoxAspirant
I'm experiencng same problem using the ReadyCloud client ver 1.9 with a RN-102. I can access the NAS via the web portal and when my laptop is attached to my LAN. But remotely, the ReadyCloud app says "connecting..." and the gear just spins. NAS has latest firmware 6.4.1.
Ideas?
- wlcoxAspirant
Yes, I have tried 2 different computers form 2 different remote locations.
Yes, it works fine when I access from a system on the same LAN as the NAS.
Re: firmware update - When I click on "check for updates" on the "system" page of the admin console, it tells me that I have the latest verson already (6.4.1) Same thing happens from the "system/settings" page. Power-cycled the NAS and it still tells me it is up to date! Are you saying I should ignore what the NAS thinks and force a firmware update?
- Any news on this, very frustrating. I've read many posts and still unable to come up with a solution. Please see my post here:
Hi,
I have a similar situation. New RN516 installed a week ago, fully accessible via network and ReadyCloud. Suddenly, can't connect to "services' on cloud tab, shows I'm connected to Internet. Also can't connect to ReadyCloud/Netgear, unit discovered but shows offline and can't see shares.
Using static IP outside DHCP on router, inside subnet, did it this way with my Ultra6 and it worked for years.
Did as suggested adding DNS server with router IP and magically I was back online. Moments later I was kicked off again. Tried entering Google DNS didn't help. Changed IP to within DHCP range and then I couldn't even get online. Changed back to outside DHCP as was connected to Internet again, but still no services on the cloud tab. Please help, always appreciated.To add to my above post, when readycloud discovers my RN516, I notice that when I try to manage it, a message comes up saying I must be on the same LAN as the computer, which I believe I am. Further, on the admin gui, cloud tab, if I click settings, I notice my device name is the original factory name of the NAS (i.e. NAS-xx-xx-xx_MAC), despite the fact that I renamed it.
Is the some sort of issue relatinf to the clients or my networks ability to resolve host names?
I also see in these settings use proxy checked and https, though no more dat in these fields. Do I need to enable http on all folders?
Getting very confused and feeling a bit helpless...
